inclined orbit | |
| Regular Member Join Date: 31-05-2006 Location: glasgow
My System: 1.2m motorised qualitv decoder manhatten blind search decoder echostar 3600ip |
I'm looking for any info on the best way to receive inclined orbit sats.I know that they cover a figure of eight flightpath but what is the best way of catching the max signal?Probably analoguesat or rd100 should know best.Any tips lads?I hope to get a 1.8m dish pretty soon and am trying more than anything to get intelsat903 *20w.I can get it at certain times but obviously it then goes out of sight.GET THE THINKING CAPS ON | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Have a look at this site - http://www.n2yo.com/?s=18350 Gives you real-time tracking info for any satellite. (Think you mean Intelsat 603) Llew | ||
My System: 1.2m motorised qualitv decoder manhatten blind search decoder echostar 3600ip | Quality site mate.Can see me spending a few days in there!How do you put in your location and how can you tell when sat is in range.Thanks again | ||
| | #5 | ||
| Specialist Contributor Join Date: 23-07-2005 Location: S.Wales
My System: 1.2M & 55cm Gregorian Dish`s, 1.5m Gibertini on a Jaeger 1224 H-H motor. Dreambox 7025 200gb HD, Vbox-II. SS2 Card. | how many sats over Europe are inclined? Is it really worth getting the mount moded for inclined sats?
__________________ Roiders are like the sun, big, orange, and never stare directly at them | ||
| | #6 | ||
My System: 1.2m motorised qualitv decoder manhatten blind search decoder echostar 3600ip | Not many mate but as feeds go most of itv and bbc and s*y are carried on this bird.I will post pics of my system soon. I have an old 1.2m prime focus (ex bookies) in the back garden that I intend setting up as well as the new 1.8m soon | ||
| | #7 | ||
My System: 1.2M & 55cm Gregorian Dish`s, 1.5m Gibertini on a Jaeger 1224 H-H motor. Dreambox 7025 200gb HD, Vbox-II. SS2 Card. | That bookies has served you well! ![]() Look forward to seeing the pics. ![]() I am thinking about getting the Jaegar 1224 for my Greg, might go for the inclined version.
| | #8 | |||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | The bottom r/hand pic gives you a general idea where your chosen sat is +/- the arc. Click on 'Track It' and the real time position info square tells you the degree of inclination +/- the arc. Llew | |||
| | #9 | ||
My System: 1.2m motorised qualitv decoder manhatten blind search decoder echostar 3600ip | Cheers Llew,will give it a blast but it gives my location as London because it uses your IP address. Crossbones will get pics up on Monday when wife is at work | ||
