What V-Box?
Thread Tools Display Modes
Old 10-02-2007   #1
CROSSBONES's Avatar
My System: 1.2M & 55cm Gregorian Dish`s, 1.5m Gibertini on a Jaeger 1224 H-H motor. Dreambox 7025 200gb HD, Vbox-II. SS2 Card.
What V-Box?
I am thinking of getting another V-box II, as the nextvision v-box I have, doesn`t have a 5V output to run my Gregorian dish motor.
Which is the best Vbox with 5v output to get?
__________________
Roiders are like the sun, big, orange, and never stare directly at them
CROSSBONES is offline   Reply With Quote
Old 10-02-2007   #2
jimbo's Avatar
My System: Sky HD, TM6800HD, Manhattan Plaza ST550 and TM1500 CI+. 1.0m dish and 36v motor, Panasonic DVD HDD recorder and Panasonic video/DVD recorder. Sony G800 HD TV stand/surround system + Sony KDL40W2000. Infinity USB, Elvis, CAS1, CAS2.
I would say this one as opposed to Moteck.
Jaeger Superjack V-Box II DiSEqC Positioner
I'm surprised you didn't see these being sold on a certain 'For Sale' section crossbones.
__________________
Jimbo
jimbo is offline   Reply With Quote
Old 10-02-2007   #3
CROSSBONES's Avatar
yes did see them, but only decided to get one in the last few days.
Is it only the Jaeger Superjack and moteck that have the 5v output?
__________________
Old 10-02-2007   #4
My System: Echostar AD3600IPVA, White Inverto 0.3db LNB, Fibo Gregorian 1.2mtr, Skystar 2
even I want to change my nextvision v-box... it skips counts with my gregorian motor...
btw how do I connect the 5v to the greorian motor.. I have just got 4 connections going to the motor (2 for the motor and 2 for the sensors) ?
olisun is offline   Reply With Quote
Old 10-02-2007   #5
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams
Not necessary if your motor uses reed switch pulsing. 5V only needed for optical switches.
__________________
Llew is offline   Reply With Quote
Old 10-02-2007   #6
Oldgeezer
johnsattuk's Avatar
My System: Topfield 5800 Echostar3000,DB7000, Relook 400S, Humax HDC2000, 55cm Fibo Gregorian dish with waveguide and Motek 2100 mod, 90cm Fibo Gregorian dish, 120cm Fibo Gregorian dish on a 1224 motor with waveguide
I saw these advertised with 5v output, and after checking by email, I ordered one.
Surprise surprise it arrived without the 5v output. The suppliers were quite apolgetic and did try and obtain the right one, but were unable to do so.
They offered money back, but I decided to keep it as most of them have a 5v supply somewhere inside, have modded a couple in the past
If you dont want to lose guarantee or do not like messing with the innards, one of the plugtop 5v will do the job.
__________________
Oldgeezer
johnsattuk is offline   Reply With Quote
Old 10-02-2007   #7
Oldgeezer
johnsattuk's Avatar
You need 5 connections to the Fibo motor
M1 - M2 - Ground - Pulse - 5v+
The 5v is only a few milliamps, you can run a single core taped to the main for the ground
__________________
Oldgeezer
Old 10-02-2007   #8
My System: Various
There's some info on modifying a V-Box to provide +5V here:
h**p://www.vetrun.com/forums/showthread.php?t=1771
Orthoclipse is offline   Reply With Quote
Old 10-02-2007   #9
CROSSBONES's Avatar
Thanks, but I wont mess with the insides!
Ill try and get one with 5v output.
Llew the greg motor, does have an optical sensor, no reed
__________________
Old 10-02-2007   #10
wod
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish
off topic but is the non 5volt vbox ok for actuators , jaeger 36v h2h motors ?
or do they still require the 5 volts ?
Old 10-02-2007   #11
Oldgeezer
johnsattuk's Avatar
Runs my 1224 OK
__________________
Oldgeezer
Old 10-02-2007   #12
CROSSBONES's Avatar
If your using a motor with a reed switch then 5volts is not required
__________________
Old 10-02-2007   #13
Llew's Avatar
Quality kit then Crossbones. Like my actuator. No sticking reeds
__________________
Old 10-02-2007   #14
CROSSBONES's Avatar
I wouldnt call the greg motor quality, as there known to fail. One of the biggest problems with these great dishes.
Mine did have a problem, but it was the common dry joint that they had. I have a couple spare, just in case.
__________________
Old 11-02-2007   #15
Sorry for sound like a newbie, but does the gregorian motor (picture on the following thread) have the 5 volt connection?
fibo pics for olisun...
I could only see 4 connections or if I can use it with the 1224 (I am planning to install the 1224 in the summer) ?
Old 11-02-2007   #16
Oldgeezer
johnsattuk's Avatar
'Gregorian' refers only to the optical principle for the dish, I think that the motor in your pics is a 'jaeger', (others may be able to identify more accurately) which I believe was used by Fibo on later production.
The origional Fibo motor with optical sensor was like attached pics.
__________________
Oldgeezer
Old 11-02-2007   #17
CROSSBONES's Avatar
I think you have the reed, 36v motor on your dish. Its the early version of the mount. It should work ok with the 1224.
Here`s what the other motor looks like.
EDIT:
You beat me too it john lol
__________________
Old 11-02-2007   #18
CROSSBONES's Avatar
There not the 5v output
__________________
Old 11-02-2007   #19
Oldgeezer
johnsattuk's Avatar
Fibo motor's optical sensor
I have in the past looked into the possibility of converting the Fibo motor from 'optical' to 'reed' output pulse but never persued it.
There seems to be a bit of renewed interest in these dishes and motors at the moment, I now have three.
With the lack of suitable diseqc boxes with 5v out, I wondered if it would be of any interest to others if I found a fairly simple way of fitting a reed. I might make a bit more effort if there if it was not just a one off for myself.
__________________
Oldgeezer
Old 11-02-2007   #20
CROSSBONES's Avatar
I blame this forum for the increase in popularity of the fibo!
You dont help with your back to life mods
I might be getting a 90cm Andas you know I am after a 55cm, so ill have the full set
I would be very interested, but wouldn`t it be easier as you have said, just to mod the vbox?
__________________
Old 11-02-2007   #21
Oldgeezer
johnsattuk's Avatar
It would be easier on a one off basis, but there are a variety of different 'V-Box's and receivers out there, some are a bit nervous about modding them, there would be guarantee issues and you would have to mod any replacement box. I am always swapping boxes and dishes about ,just for fun. And then you have to run an extra wire.
I have just bought some nice shotgun RG6 + 4wire motor, but it is only 4 wire and I would have to run an extra wire myself if I modded the box, this is one of the reasons I thought about revisiting the reed switch idea. I will look into it a little, I have some ideas about an easy way, if I can get the right bits and pieces.
Used to be able to get shotgunned cable with 5core, but havn't seen any for a while.
__________________
Oldgeezer
Old 11-02-2007   #22
there was one 90cm Fibo on fleabay last week but I couldn't find the Bargain dishes thread to post the details
Ebay 300074747773
Old 11-02-2007   #23
Oldgeezer
johnsattuk's Avatar
Stu - doing some recyling
__________________
Oldgeezer
Old 11-02-2007   #24
Heh...no one bought the Fibo.
I wouldn't have either without any pictures showing it's condition.
Likvid is offline   Reply With Quote
Old 11-02-2007   #25
CROSSBONES's Avatar
That is what im using shotgun 5 core, but split the old coax as it was no good. Think I will have a go at modding my vbox
Yes that was one of stu`s fibo`s back on e-bay olisun.
__________________
[IMG] code is Off
