what size pole | |
| Regular Member Join Date: 03-02-2007 Location: UK exeter
My System: technomate 6900 hd darkbox rev 2007 104cm gibertini dish. moteck 2100a with diseqc 12 |
hi guys what size mast pole should i get for a 90cm dish to be about 6ft high thanks have seen 1/1/4 is inch quarter ok for t with motorised dish | ||
| Specialist Contributor Join Date: 23-07-2005 Location: S.Wales
My System: 1.2M & 55cm Gregorian Dish`s, 1.5m Gibertini on a Jaeger 1224 H-H motor. Dreambox 7025 200gb HD, Vbox-II. SS2 Card. | Is it ground mounted or are you using T & K brackets on a wall? If your using T & K`s then use a length of scaffolding pole, about 2" is fine.
__________________ Roiders are like the sun, big, orange, and never stare directly at them | ||
My System: technomate 6900 hd darkbox rev 2007 104cm gibertini dish. moteck 2100a with diseqc 12 | using a wall mount bracket that came with the dish package its like a swans neck so it misses the overhang on the roof | ||
| Specialist Contributor Join Date: 18-12-2004 Location: no mans land
My System: two sky+amstrad boxes technomate5500ci+ with 80cm motarised dish irderto cam mr mrev +dragoncam blue tit numerous fun cards infinity pheonix compaq and dell on wirelessrouter | mine is on t and k brackets with a scafold bar fixed to them enabling the dish to go above the guttering the braket that came with my system is unused in the garage hope this helps | ||
| | #5 | ||
My System: 1.2M & 55cm Gregorian Dish`s, 1.5m Gibertini on a Jaeger 1224 H-H motor. Dreambox 7025 200gb HD, Vbox-II. SS2 Card. | maybe you wont need the pole? Cant you just bolt the polar mount to the "swan`s neck"?
| | #6 | ||
| Donate to this board Join Date: 05-09-2006 Location: So called capital of Suffolk, UK.
My System: Smart lnb, 1m Gibby dish, Stab motor, TM5200D receiver, 57east to 61west. DTT from Sudbury. Virgin Media broadband. | Problem with that type of bracket (swan neck) for a motorised system is that it is liable to flex as the dish is moved from east to west. Hence you will not follow the arc correctly. I think that you will find that wod has similar problems when he set up his motorised dish and now has T&K's with a pole between them. PR | ||
| | #7 | ||
| Specialist Contributor Join Date: 07-08-2005 Location: west yorkshire, uk
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish | yes i got rid of the l shaped bracket as in fact it bent in the winds we had some weeks back 18" t&ks and 1.5metre 2inch scaffold pole i've used which is now solid | ||
| | #8 | ||
going to get some t*ks plus 2in pole tomorrow best be safe than sorry thanks guys wheres the cheapest place to buy this stuff thanks | ||
| | #9 | ||
My System: two sky+amstrad boxes technomate5500ci+ with 80cm motarised dish irderto cam mr mrev +dragoncam blue tit numerous fun cards infinity pheonix compaq and dell on wirelessrouter | den123 sorry m8 i cant help you there the tk,s i got for free of a good mate and the scaff bar i borroweed of a building site | ||
| | #10 | ||
My System: 1.2M & 55cm Gregorian Dish`s, 1.5m Gibertini on a Jaeger 1224 H-H motor. Dreambox 7025 200gb HD, Vbox-II. SS2 Card. | maplins sell the T & K`s. Do what wolfav has done borrow from a building site ![]() Or try your local engineering firm
| | #11 | ||
My System: Smart lnb, 1m Gibby dish, Stab motor, TM5200D receiver, 57east to 61west. DTT from Sudbury. Virgin Media broadband. | I buy scaffold poles from my local SGB (Scaffolding Great Britain), any scaffold merchand will sell you a length of pole. PR | ||
