a beginner's begging for advice | |
| Regular Member Join Date: 24-07-2003
Hi Everyone, I have a static dish pointing to 28.2 east with Echostar 707 FTA. here is the image of dish itself: http://medstud.pote.hu/~gh/dish/dish.jpg I usually watch the channels on ASTRA2 (28.2E) but sometimes I'd like to tune into BBC News24 which is on ASTRA 1 (19.2E). Usually I take a walk to the balcony ( I live in the 10th floor) with a wrench and make the adjustment manually. I heard there are ways to make it more comfortable with twin LBNs or motorized systems but I don't know how to start with such a project. I'd like to do it myself and would be nice if it won't cost too much :-) . I'd be extremely grateful if someone could put me in the right directions. Any comments would be warmly appreciated. Best Regards Péter | ||
| | #2 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Hi Péter, BBC news 24 is on 28.2 E as well, so no need to move the dish 10773 H SR 22,000. You can of course get yourself an LNB arm and a DiseqC switch and switch between the two satellite, there is quite a lot of interesting programming on Astra 19.2.
__________________ | |||
| | #3 | |||
Sadly I dont't know much about the technical details of DiseqC, how it operates and what are the prerequisites installing (preferably myself) such a device I wonder if you could send me an URL or any document from I can learn more about this subject. Best regards Péter Last edited by bachopin; 31-01-2004 at 08:25 PM | |||
| | #4 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | DiseqC is really pretty straightforward Péter, it is merely a switching method. The diseqC switches available are normally 2 or 4 satellite, so you would connect Astra 28.2 to port A and Astra 19.2 to port B. You then go into LNB setup in your receiver menu and select Astra 28.2, then under the DiseqC section, call it A or 1, then do the same for 19.2, but call it B or 2.
| | #5 | |||
Regards Péter | |||
| | #6 | ||
| Guest
Posts: n/a
| Hi Bachopin Here is a picture and information on DisecQ switches http://www.dmsiusa.com/diseqc_switches.htm Also a picture and information about a double LNB holder here http://www.targetweb.nl/txt/tx28234.htm I am sure that a satellite dealer in your country will be able to supply you with the necessary equipment. You will obviously need extra co-axial cable and connectors for the second LNB, do not forget to seal all your joints so that moisture does not get in. gmbp PS nice picture of your dish Last edited by gotmybuspass; 01-02-2004 at 12:19 AM | ||
| | #7 | |||
Sorry for the long delay in my reply. I'm going to buy a DiseqC switch with cables which should be quite straightforward hopefully. The only dilemma for me is what kind of LNB should I use for the second head. Is there anything I should be aware of when I buy one ? I mean anything to look for in the technical specifications of LNBs. My offset antenna is 60cm - and I got all ASTRA 2A signals without problem - but I don't know the current technical spec. of the LNB being currently used - I found nothing relevant to it on the head. Thanks again for all who replied to my question - you all helped me a lot ! Best wishes Péter | |||
| | #8 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Any reasonable quality Universal LNb should do Péter, on looking at the LNB arm though, you may need to make adaptations to a standard offset, unless they make one specifically for that dish.
| | #9 | ||
| Regular Member Join Date: 27-08-2003 Location: UK
| BBC News is not, as far as I am aware, available on Astra 19. BBC World is, but it is not the same as BBC News on Astra 28. You probably know that anyway Peter. Good luck with your project. | ||
Similar Threads | ||||
| Beginner's guide to editing keys? | BigSat4U | Receiver software, international Section | 2 | 20-07-2006 10:53 PM |
| Are there any plans for a beginners board? | icebergx | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 7 | 06-03-2006 06:49 PM |
| Beginners guide needed please!! | merv7419 | Cams and decoders General | 1 | 11-12-2004 07:29 PM |
| Pic-cards: manufacturing, programming, use (the information for beginners) | Anatoli | Cards & Programmers General | 0 | 09-02-2003 11:35 AM |
| going motorised (for beginners) | howard | Digital systems | 0 | 27-03-2001 08:13 PM |
