make smart priority switch weatherproof | |
| Member Join Date: 04-03-2006 Location: UK
My System: Astra/Hotbird |
hi, i would like to install a sps1 directly to the dish, making it weatherproof somehow. what would be the best way to do this or shouldn't this be done at all? thanks. marty80 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | If it's a Global switch, unlike that maker's DisecQ switches, it has no weatherproof cover. If it's to go outside in an exposed position, you will have to make sure the plugs are well weatherproofed with amalgamating tape (as with an LNB). Llew | ||
My System: Astra/Hotbird | i want to add another receiver which is in another room. so i would have to run two cables inside. if i place the sps1 at the dish, i only need one cable. if i seal the sps1 and plugs in carefully, it should be ok, or not? | ||
| | #6 | ||
| Regular Member Join Date: 28-01-2006 Location: Cheshire
My System: Sky+HD Astra+Hotbird FTA on 60 cm dish | Id install it inside a suitable enclosure like an IP56 rated adaptable box using stuffing glands to run the cables into the box. | ||
| | #7 | ||
| Amo Amas Amant Admin Join Date: 18-11-2004 Location: NW England (Siberia)
My System: IDD CI24 ECONO MM Penta 1.20 Galaxy II 1.2Mtr Polar MTG yes it has been on the arc for 21 years and is still driven by a modified wiper motor from a Ford Anglia. It's like me sometimes groans but always performs ![]() Saved us from the black plague of ignoratio elenchi, he awaits a special badge with jugs | If you were going down that road, I would suggest IP55 with plugged drainholes facing down as this will allow any condensation (which is bound to form with the wide range of temperatures it will experience)to exhaust to the atmosphere without letting further moisture in otherwise any moisture will be trapped inside and may hasten a unit failure
__________________ War does not determine who is right, it determines who is left! Formerly toppervte33h whose six pack has turned into a keg Help support this web site by making a donation Or use other options to help support Sats UK Show Your Support by clicking the button ![]() Thank you. Freddie Flintoff is back | ||
| | #8 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | I would be more inclined to fit a twin output monobloc, or twin LNBs with two DiseqC switches (whichever setup you have), would then give independent operation.
__________________ | |||
| | #9 | ||
My System: Astra/Hotbird | rolfw's suggestion seems most sensible to me now. i was just reluctant to buy yet another lnb. (first i had a single one, then a twin, then a twin monobloc and now a quad monobloc) by the way, can you switch a quad monobloc (which already has a diseqc switch) together with a quad lnb via diseqc? thanks a lot! | ||
| | #10 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Sorry, I'm confused now, can you sketch what you have please.
| | #11 | ||
My System: Astra/Hotbird | i'm actually thinking about a motorized system now because i know i will just keep on upgrading and wasting money. all the lnbs together would nearly buy one. or what would be the cost of a motorized system plus installation? (now i've got an 80cm dish with a twin monobloc) | ||
| | #12 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | No, still very confused, as you mention twin monobloc, then quad monoblock and then a quad LNB, what is that one connected to?
| | #13 | ||
My System: Astra/Hotbird | sorry about that. i've now got a twin monobloc which would be replaced by a quad monobloc. i mentioned the quad lnb because i was thinking about getting another dish in the future for 28.2e with a quad lnb. the question was if it was possible to switch together a quad monoblock and a quad lnb via diseqc. i don't know much about dish setup, especially diseqc, etc. but then digiboxes don't support diseqc switching. so much i do know. i decided on getting a quad monobloc now and my little problem is therfore solved. many thanks! | ||
| | #14 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | OK, but I'm still slightly confused, as if you only have one receiver at present, why do you need more than a twin monobloc for just two receivers?
| | #16 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | OK, sorry didn't notice that.
