strong 4375 problems installing for analogueInformation exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| Member Join Date: 01-02-2004
after repair of my strong 4375 i try to reinstall my favorites. I use fixed dish with two heads for Astra digital and Hotbird analogue resp. Digital astra inmediatly succesfull. Analogue Hotbird not succesfull. No channel does appear. What did I wrongly? Loop in loop out connected. antenna connected to lnb d. Please advise. ronn | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Did you set the DiseqC setting for Hotbird in the satellite/LNB menu? | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | I'm making the assumtion that you have a DiseqC switch and only have a single cable coming into the receiver . You have to go into the LNb/satellite setup menu Ronn, not sure about what the menus are called on the strong, but you need to enable DiseqC on the second LNB and call it 2 or B, then you should be able to see the second sat. | ||
| | #5 | |||
| | #6 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Great stuff Ronn, good to see that you are back up and running. | ||
| 4375, analogue, installing, problems, strong |
Similar Threads | ||||
| Strong 4375 upgrade | refinechange | Receiver software, international Section | 5 | 30-01-2008 02:07 PM |
| MR on Strong 4375 (& Hispasat) | Godzuki | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 5 | 04-05-2004 08:39 PM |
| Few people seek help for sex problems | net1 | The Meeting Place | 0 | 22-08-2003 08:11 PM |
| strong srt 4375 problems | jamie2001 | Transponders & channels | 17 | 12-11-2001 01:09 PM |
| Problems with Strong 4375 firmware 1.01 upgrade | Stargazer | Receiver software, international Section | 4 | 07-02-2001 11:06 AM |
