2 receviers
Thread Tools Display Modes
Old 25-02-2007   #1
My System: technomate 6900 hd darkbox rev 2007 104cm gibertini dish. moteck 2100a with diseqc 12
2 receviers
hi guys can i connect 2 receviers to my 1 dish looking to put another box in bedroom
den123 is offline   Reply With Quote
Old 25-02-2007   #2
Amo Amas Amant Admin
Topper's Avatar
Yes
But I suggest you do it properly by buying a twin (two outputs) or quad (four outputs) lnb, you will have to check if the mountings are compatible with the existing lnb though
__________________
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
Old 25-02-2007   #3
i have a motorised dish so will it still work ok if i get a twin lnb
Old 25-02-2007   #4
rolfw's Avatar
Yes, but the second receiver will only be able to watch the satellite which the main receiver sends the dish to.
__________________
Rolf
Donate
Old 25-02-2007   #5
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams
Yes, but only one STB must be used to control the dish.
__________________
Llew is offline   Reply With Quote
Old 25-02-2007   #6
Llew's Avatar
Your call Rolf. Must type faster
__________________
Old 26-02-2007   #7
My System: KU BAND
instead of connecting both STBs to dish, connect one STB to dish & take output from that STB for next STB
Karuna67 is offline   Reply With Quote
Old 26-02-2007   #8
Llew's Avatar
That will restrict the slave receiver's choice of channels to whatever the main STB has switched the LNB's polarisation to (either horizontal or vertical).
__________________
Old 26-02-2007   #9
Section Leader
member91040's Avatar
My System: DISH TV,DIRECT DD+, TATA SKY,HATHWAY, NOKIA 9660S, PCI SAT CARD TWINHAN NSS6, PAS7/10, ASIASAT3S, INSAT,INETEL SAT, EUROSTAR, DremBox, & Multi LNB'S
If i connect One output to two receivers by splitting up, The signal is dropping, I want to use one receiver at a time. Sol for this.
__________________
member91040 is offline   Reply With Quote
Old 26-02-2007   #10
Llew's Avatar
A/B switch. (Some loss there though). Make sure you only use one STB for dish control if dish is motorised.
__________________
Old 26-02-2007   #11
Section Leader
A/B Switch. Looks like manual way, No other way Automatically.
__________________
Old 26-02-2007   #12
rolfw's Avatar
You can use a smart priority switch.
__________________
Rolf
Donate
[IMG] code is Off
Forum Jump
