Pictorial Setup Guide for DiSEqC Motor - Downloadable PDF
Old 10-03-2007   #1
rolfw's Avatar
Real name: Rolf
My System: Sky+, DB 7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Spectrum analyser.
Here is a little pictorial setup guide.
EDIT. Have now uploaded as a PDF file. Feel free to print it out.
How to fit an "F" Connector
Notes about your due South satellite
Although I have used Thor 1W as my due South satellite, this is merely because the longitude of my location is actually 1W. If you are situated further East or West, then find your longitude from somewhere like www.multimap.com or www.heavens-above.com and then look at www.lyngsat.com to find the nearest satellite to your longitude.
If there is not a convenient receivable satellite at your actual due South, then pick the nearest one. To make allowance for the fact that it is not exactly due South, a satellite receiver with USALS/GoToX (once your coordinates have been entered), can send the motor to where it thinks the satellite should be and then you can use the alignment procedure as described above, the arc should then be near perfect. If your receiver or motor does not have this automatic system, manually drive the motor by an approximate amount of degrees using the scale on the motor body.
Happy dish fitting.
Rolf
The Following 21 Users Say Thank You to rolfw For This Useful Post:
acezon (18-08-2008), bacardi (02-06-2008), Bullish (2 Weeks Ago), Chezzdevil (27-03-2008), ctooi (22-03-2008), disjoint (14-08-2008), gypsydog (20-12-2008), HB13DISH (20-10-2007), homerhat (07-08-2007), hutchy41 (27-05-2007), joek130 (21-08-2008), mad_elf (30-12-2008), Muad'Dib (25-08-2008), paaa (20-06-2007), Parsasat (03-04-2008), rolks (05-05-2009), sharp (27-07-2009), spearmintone (4 Weeks Ago), swimmer (22-12-2008), SwitchedOn (27-02-2009), wurzel (03-02-2009)
Old 10-03-2007   #2
CROSSBONES's Avatar
My System: 1.2M, & 55cm Gregorian Dish`s, 1.8m Precision dish Jaeger 1224 H-H motor.Dreambox 800, Vbox-II. SS2 Card.
Excellent guide Rolfw
Whos that guy hiding behind the dish? lol
And its not a sticky!
CROSSBONES is offline   Reply With Quote
Old 10-03-2007   #3
Lancelot's Avatar
My System: SS1. 3.4Ghz P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H 62E - 61W
...And thou were the truest friend to thy lover that ever bestrad horse..."
Sad but I recognise that particular install.
Done for one of the members here I think
L.
Support our Advertisers
I've got an inferiority complex, but it's not a very good one.
Lancelot is offline   Reply With Quote
Old 10-03-2007   #4
rolfw's Avatar
Real name: Rolf
LOL, very difficult to hide behind a transparent dish.
Rolf
Old 10-03-2007   #5
wod
wod's Avatar
My System: andrews dish - jaeger 1224 motor, vantage x221tsci, skystar 2, diablo v2.3, cyfra+
good you mention about the moteck motor bracket bolts shearing off as i nearly did that
cutting the dish bracket bolts down as that is actually a good idea as it pulled the cables out of my motor because i had the dish too high up the motor
very good guide, pointed out to me things i skipped over
Old 11-03-2007   #6
CROSSBONES's Avatar
I bet someone will put that on e-bay as an ebook!
Old 11-03-2007   #7
Amo Amas Amant Admin
Topper's Avatar
Mmm
It is now unless Rolf wants to unstick it, but why should he want to hide such a good tutorial?
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
Old 11-03-2007   #8
Mad Scientist
OldBen's Avatar
My System: Technomate 1500CI+, Moteck DG2100 DisEqC Motor, Metronic 85cm Clear Dish, Invacom 0.3db LNB.
Yes but you look like a pro, do you practice? or just watch too much Tim "the toolman" Taylor talking to his neightbour
OldBen is offline   Reply With Quote
Old 27-03-2007   #9
Thank Me not my Boobs
Leee's Avatar
My System: Sky+ v2 (120Gb); DM7020Si*motorised; PC/S2-3200
rolf, I've a question as I'm about to motorise;
I'm at 8e which means 7e is my reference bird. Now do I line up on that pup at 0 on the motor? Part (most of me) thinks yes but some of me thinks no.
Ta v. muchy indeed - Lee(eeeee)
Leee is offline   Reply With Quote
Old 27-03-2007   #10
rolfw's Avatar
Real name: Rolf
Yes, Lee, line up on 7E, you can account for the slight offset by setting your receiver with USALS and sending your motor to 7E, that way you will have perfect due South alignment when you find 7E.
Rolf
Old 11-04-2007   #11
My System: motorised 80cm sat catcher reciever
reference sat
im just about to do my first motorised install. my question is what should be my reference satellite? my location is chester in the north west, uk. 53.192°N, 2.876°W should i use thor? also i will be using it to view french channels, are there many in the clear? any help much appreciated. great guide by the way. cleared up a lot of things for me.
ashleydylanbest is offline   Reply With Quote
Old 11-04-2007   #12
rolfw's Avatar
Real name: Rolf
As per the answer above, use the satellite which is closest to your due South, you could use either 5W or 1W, if you are looking for French channels, then 5W is the one to go for. Remember to offset the motor slightly to account for the difference between 5W and your longitude.
Rolf
Old 12-04-2007   #13
thanks
many thanks
The Following User Says Thank You to ashleydylanbest For This Useful Post:
mjamil (31-07-2007)
Old 05-05-2007   #14
rolfw's Avatar
Real name: Rolf
Fitting an F connector, Snap 'n' seal type
How to fit an F connector
Click on individual thumbnails to enlarge them
The procedure is largely the same for screw on type "F" connectors.
Strip the cable, about 1/4" on both sections
Pictorial Setup Guide for DiSEqC Motor - Downloadable PDF-cable1-jpg
Fold back the braid (For a screw on type "F" Connector, simply now screw on until the dialectric plastic core touches the end of the connector barrel)
Pictorial Setup Guide for DiSEqC Motor - Downloadable PDF-cable2-jpg
If you pushing on the connector now with the foil and it bundles up as in the picture above, strip it off, or a good way to prevent this happening is to turn the connector around and gently twist over the copper screen, this will smooth the edges and allow for smooth insertion of the connector in most cases
Pictorial Setup Guide for DiSEqC Motor - Downloadable PDF-cable3-jpgPictorial Setup Guide for DiSEqC Motor - Downloadable PDF-cable4-jpg
Push on the connector with the braid still pulled back over the outer, a warm cable makes it easier
Pictorial Setup Guide for DiSEqC Motor - Downloadable PDF-cable5-jpg
Then crimp.
Pictorial Setup Guide for DiSEqC Motor - Downloadable PDF-cable6-jpgPictorial Setup Guide for DiSEqC Motor - Downloadable PDF-cable7-jpg
This style of compression connector if fitted with an "O" ring, is waterproof when tightly fitted, but it is advisable to waterproof with self amalgamating tape, if no "O" ring is fitted or if you are using screw on or crimp type connectors.
Rolf
Old 13-10-2007   #15
My System: ClarkeTech 2100Plus USB + Triax 88DL+Moteck (Palm) 2100A motor, Home-Theatre AV System, LCD-TV, PC, HTC TyTN & TyTN II, HTC S620
location is N64.1, E27.7, could you kindly tell me what would be the best reference satellite? Astra 2 or Badr?
bjluv is offline   Reply With Quote
Old 13-10-2007   #16
rolfw's Avatar
Real name: Rolf
Astra 2, good strong satellite, pick a transponder on the North beam.
Rolf
Old 13-10-2007   #17
what transponder should i take from the north beam? im a newbie remember
Old 22-10-2007   #18
Supporting Advertiser
cdtronix's Avatar
My System: TM6800 HD Super+, TM5400CI, Triax 1.1m Dish & Moteck Motor, also Triax 78cm Dish with Moteck motor. Global Single LNB, Ice Quad LNB.
thats a nice guide there thanks, will come in useful !!!
cdtronix is offline   Reply With Quote
Old 22-10-2007   #19
Archived Member
Great Thread
Thanks a lot rolf for this thread and for the first post with details about how to use motors.
I must admit that before reading the post, I never thought that I would have the knowledge to do anything about motorizing a dish, but now I am sure that I can.
After reading more threads about motors, I understand that there are basically two DISEQ models made by Moteck and Stab.
I was considering also a Manhattan, but then I read that it is made by Stab.
Has there been any major players in this arena apart from Moteck and Stab or better specifications and quality ?
Would the receiver be matched to the motor with all the settings and so if another similar receiver is used (or a new image is installed), the motor would have to be reset again ?
There are claims that the motor is not fixed well to the dish and therefore the dish might snap off more easily than a fixed dish and could cause accidents flying off the roof.
My problem at the moment is that I don't have at my present dwelling a lot of space movement eversince they built several high buildings around. In fact I was lucky to have a little spot for Hot Bird so a large arc would be in my dreams.
I might be able to experiment somewhere else, perhaps at friends or relatives roofs, but it will not be the same as at your own home.
So at the moment I am just trying to gather the right information and hopefully one day I can put it to practice.
HB13DISH is offline   Reply With Quote
Old 22-10-2007   #20
rolfw's Avatar
Real name: Rolf
There are a couple of other makes, but most of the other ones around are clones of the Moteck, Jaeger or Stab (in fact the Moteck was originally a Jaeger clone I believe).
If a dish were to be mounted in an exposed position, then I would be inclined to limit the size to 90cm, I have not yet heard of any incidences of motor arms dropping off, but there is obviously a limit as to how much weight it is sensible to hang off of one.
Rolf
Old 03-01-2008   #21
vma
vma's Avatar
Just a small comment:
On my first installation, I tried to use the satellite position closest to the true south.
Today, after a few other installations, I am of the opinion, that it is far easier, to manually rotate the motor to 13.0E and search for Hotbird. The advantage is that this satellite has a) a stronger signal and b) still has a few analog TV channels, maken the alignment easier for those who don't have access to a spectrum analyzer.
Cheers,
vma
vma is offline   Reply With Quote
Old 03-01-2008   #22
Robbo's Avatar
Real name: Mark
Cheers,
vma
I agree, it can be easier for newbs to find Hotbird, and I have done the same. But I additionally would wack it round to 1W( my nearest south) and re-adjust if necessary. Not doing it at the top of the arc, is not as accurate, as it is easier to centre the dish on the beam, at the top of the arc.
Robbo is online now   Reply With Quote
Old 17-01-2008   #23
My System: triax 90cm dish echolink 888 recever diseg motor
re setup instructions
Very good set of instructions just have couple of questions.
Wot do you recomend as a good lnb.
Wot is the diffrence in lnbs.
My long is 1:19:10W.
My lat is 53:25:58N.
Do i just use first 4 digits of lat and 3 digits of long.
And wot is nearist satelite to me am i right in thinking thor at 1w.
r1chard06 is offline   Reply With Quote
Old 17-01-2008   #24
Robbo's Avatar
Real name: Mark
Have a search of the forum, or start a new topic.
You may need to convert the values to decimal, and then put in as many digits as the receiver will allow and still look correct. eg 51.25N not 512.5N
Yes it is 1W since your longitude is 1:19:10W.
Robbo
Old 17-01-2008   #25
Thanks im new to this forum thing and satelite
arc, brackets, darkmotor, diseqc, guide, howto, install, moteck sg2100, motor, pictorial, satellite, setup
[IMG] code is Off
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. Uptime monitoring by PageUtils.com
