Setup Guide for DiseqC motor - Pictorial | |
| | #1 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. |
Here ia a little pictorial setup guide. ![]() http://www.satellite-newbie.co.uk/sat1/diseqcinstall.html How to fit an "F" Connector Notes about your due South satellite Although I have used Thor 1W as my due South satellite, this is merely because the longitude of my location is actually 1W. If you are situated further East or West, then find your longitude from somewhere like www.multimap.com or www.heavens-above.com and then look at www.lyngsat.com to find the nearest satellite to your longitude. If there is not a convenient receivable satellite at your actual due South, then pick the nearest one. To make allowance for the fact that it is not exactly due South, a satellite receiver with USALS/GoToX (once your coordinates have been entered), can send the motor to where it thinks the satellite should be and then you can use the alignment procedure as described above, the arc should then be near perfect. If your receiver or motor does not have this automatic system, manually drive the motor by an approximate amount of degrees using the scale on the motor body.Happy dish fitting.
__________________ | |||
| The Following 12 Users Say Thank You to rolfw For This Useful Post: |
| Specialist Contributor Join Date: 23-07-2005 Location: S.Wales
My System: 1.2M & 55cm Gregorian Dish`s, 1.5m Gibertini on a Jaeger 1224 H-H motor. Dreambox 7025 200gb HD, Vbox-II. SS2 Card. | Excellent guide Rolfw ![]() Whos that guy hiding behind the dish? lol And its not a sticky!
__________________ Roiders are like the sun, big, orange, and never stare directly at them | ||
| Nasty Dish Obsession Join Date: 01-06-2004 Location: Oxfordshire
My System: SS1. 3.4Ghz Dual Core P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." | Sad but I recognise that particular install. Done for one of the members here I think L.
__________________ I've got an inferiority complex, but it's not a very good one. | ||
| | #4 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | LOL, very difficult to hide behind a transparent dish.
| | #5 | ||
| Specialist Contributor Join Date: 07-08-2005 Location: west yorkshire, uk
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish | good you mention about the moteck motor bracket bolts shearing off as i nearly did that cutting the dish bracket bolts down as that is actually a good idea as it pulled the cables out of my motor because i had the dish too high up the motor very good guide, pointed out to me things i skipped over | ||
| | #6 | ||
My System: 1.2M & 55cm Gregorian Dish`s, 1.5m Gibertini on a Jaeger 1224 H-H motor. Dreambox 7025 200gb HD, Vbox-II. SS2 Card. | I bet someone will put that on e-bay as an ebook!
| | #7 | ||
| Amo Amas Amant Admin Join Date: 18-11-2004 Location: NW England (Siberia)
It is now unless Rolf wants to unstick it, but why should he want to hide such a good tutorial?
__________________ War does not determine who is right, it determines who is left! Formerly toppervte33h whose six pack has turned into a keg Help support this web site by making a donation Or use other options to help support Sats UK Show Your Support by clicking the button ![]() Thank you. Freddie Flintoff is back | ||
| | #8 | ||
| Mad Scientist Join Date: 29-07-2005 Location: UK
My System: Technomate 1500CI+, Moteck DG2100 DisEqC Motor, Metronic 85cm Clear Dish, Invacom 0.3db LNB. | | ||
| | #9 | ||
| Thank Me not my Boobs Join Date: 19-12-2002 Location: 47°N/8°E/490m
My System: Sky+ v2 (120Gb); DM7020Si*motorised; PC/S2-3200 | rolf, I've a question as I'm about to motorise; I'm at 8e which means 7e is my reference bird. Now do I line up on that pup at 0 on the motor? Part (most of me) thinks yes but some of me thinks no. Ta v. muchy indeed - Lee(eeeee) | ||
| | #10 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Yes, Lee, line up on 7E, you can account for the slight offset by setting your receiver with USALS and sending your motor to 7E, that way you will have perfect due South alignment when you find 7E.
| | #11 | ||
| ASBO Club Member - Persona non grata Join Date: 11-04-2007 Location: chester uk
My System: motorised 80cm sat catcher reciever |
im just about to do my first motorised install. my question is what should be my reference satellite? my location is chester in the north west, uk. 53.192°N, 2.876°W should i use thor? also i will be using it to view french channels, are there many in the clear? any help much appreciated. great guide by the way. cleared up a lot of things for me. | ||
| | #12 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | As per the answer above, use the satellite which is closest to your due South, you could use either 5W or 1W, if you are looking for French channels, then 5W is the one to go for. Remember to offset the motor slightly to account for the difference between 5W and your longitude.
| | #14 | |||
How to fit an F connector Click on individual thumbnails to enlarge them The procedure is largely the same for screw on type "F" connectors. Strip the cable, about 1/4" on both sections cable1.jpg Fold back the braid (For a screw on type "F" Connector, simply now screw on until the dialectric plastic core touches the end of the connector barrel) cable2.jpg If you try the connector now with the foil, it may bundle up the foil as in the picture above, so strip it off cable3.jpgcable4.jpg Push on the connector with the braid still pulled back over the outer, a warm cable makes it easier cable5.jpg Then crimp. cable6.jpgcable7.jpg This style of compression connector if fitted with an "O" ring, is waterproof when tightly fitted, but it is advisable to waterproof with self amalgamating tape, if no "O" ring is fitted or if you are using screw on or crimp type connectors.
| | #15 | ||
| Member Join Date: 13-09-2007 Location: Finland
My System: ClarkeTech 2100Plus USB + Triax 88DL+Moteck (Palm) 2100A motor, Home-Theatre AV System, LCD-TV, PC, HTC TyTN | location is N64.1, E27.7, could you kindly tell me what would be the best reference satellite? Astra 2 or Badr? | ||
| | #16 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Astra 2, good strong satellite, pick a transponder on the North beam.
| | #17 | ||
My System: ClarkeTech 2100Plus USB + Triax 88DL+Moteck (Palm) 2100A motor, Home-Theatre AV System, LCD-TV, PC, HTC TyTN | what transponder should i take from the north beam? im a newbie remember | ||
| | #19 | ||
| Super Moderator Join Date: 13-08-2007 Location: Middle East - Israel
My System: Satellite Dish 1.6m Hotbird 13E, DreamBox 7000S with Gemini 4.5.0; Dish 1.2m Amos 4W, Nokia 9600S; Nokia 9800S; Hauppauge Nexus-S PCI Card ![]() He battled for 3 days against the Tux and won! Hurray!! |
Thanks a lot rolf for this thread and for the first post with details about how to use motors. I must admit that before reading the post, I never thought that I would have the knowledge to do anything about motorizing a dish, but now I am sure that I can. After reading more threads about motors, I understand that there are basically two DISEQ models made by Moteck and Stab. I was considering also a Manhattan, but then I read that it is made by Stab. Has there been any major players in this arena apart from Moteck and Stab or better specifications and quality ? Would the receiver be matched to the motor with all the settings and so if another similar receiver is used (or a new image is installed), the motor would have to be reset again ? There are claims that the motor is not fixed well to the dish and therefore the dish might snap off more easily than a fixed dish and could cause accidents flying off the roof. My problem at the moment is that I don't have at my present dwelling a lot of space movement eversince they built several high buildings around. In fact I was lucky to have a little spot for Hot Bird so a large arc would be in my dreams. I might be able to experiment somewhere else, perhaps at friends or relatives roofs, but it will not be the same as at your own home. So at the moment I am just trying to gather the right information and hopefully one day I can put it to practice. | ||
| | #20 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | There are a couple of other makes, but most of the other ones around are clones of the Moteck, Jaeger or Stab (in fact the Moteck was originally a Jaeger clone I believe). If a dish were to be mounted in an exposed position, then I would be inclined to limit the size to 90cm, I have not yet heard of any incidences of motor arms dropping off, but there is obviously a limit as to how much weight it is sensible to hang off of one.
| | #21 | ||
| Member Join Date: 17-05-2007 Location: Portugal
| Just a small comment: On my first installation, I tried to use the satellite position closest to the true south. Today, after a few other installations, I am of the opinion, that it is far easier, to manually rotate the motor to 13.0E and search for Hotbird. The advantage is that this satellite has a) a stronger signal and b) still has a few analog TV channels, maken the alignment easier for those who don't have access to a spectrum analyzer. Cheers, vma | ||
| | #22 | |||
My System: TM6800HD+TD110+StabHH90 motor,TM1000D+Orbital 1m Multifeed 16E,23E,28E.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox. |
| | #23 | ||
| Member Join Date: 16-01-2008 Location: yorkshire
My System: triax 90cm dish echolink 888 recever diseg motor |
Very good set of instructions just have couple of questions. Wot do you recomend as a good lnb. Wot is the diffrence in lnbs. My long is 1:19:10W. My lat is 53:25:58N. Do i just use first 4 digits of lat and 3 digits of long. And wot is nearist satelite to me am i right in thinking thor at 1w. | ||
| | #24 | ||||
My System: TM6800HD+TD110+StabHH90 motor,TM1000D+Orbital 1m Multifeed 16E,23E,28E.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox. | Have a search of the forum, or start a new topic.
Robbo | ||||
