Humax 5400z Reference SatelliteInformation exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| "Satellite Expert" Join Date: 01-01-2000 Location: Kernow
My System: Humax IRCI5400z, Sony Digibox, Digilogic Freeview box, 1.1m Triax, Manhattan DiSEqC mount, various cards, Season Interface |
I've just read the instruction manual for my Hummie, but nowhere I canI find a reference to a reference satellite (if you see what I mean). On the 5 deg W Antenna Settings menu (ToH 3.2 patch), there is a category called Reference Satellite but, when I try to use it, the STB refuses to accept the command. It would be enormously useful if I could recalculate all satellite positions from one settings. Is this possible? | ||
| wolsty | |||
| Salty Tech Monster Mod Join Date: 17-11-2003 Location: South East England
My System: TM-5400 CI+USB Super. Cryptik Digital H-H Mount. Diablo 2.3 Light. Cas 3+ | Have you not tried the official site's for info Woltsy? this looks like it's worth a browse m8 http://www.humaxdigital.com/ | ||
My System: Humax IRCI5400z, Sony Digibox, Digilogic Freeview box, 1.1m Triax, Manhattan DiSEqC mount, various cards, Season Interface | Thanks Waverider. I downloaded a manual from the Humax site, which is later than mine, but effectively identical. However, when reading through it, I found exactly what I was looking for. I'm not sure I understand it (the manual has lost something in the translation), but I'll give it some study and see if I can dig out the information I want. | ||
| wolsty | |||
My System: TM-5400 CI+USB Super. Cryptik Digital H-H Mount. Diablo 2.3 Light. Cas 3+ | Yes it's always best to read things over a couple of times and then the penny drops! | ||
| | #5 | ||
My System: Humax IRCI5400z, Sony Digibox, Digilogic Freeview box, 1.1m Triax, Manhattan DiSEqC mount, various cards, Season Interface | I was hoping that the receiver would automatically recalculate the position of satellites from a single reference after I've adjusted the mount. It appears that the 5400 does not have this facility and that the reference setting is just 0 degs, ie press reset and the stb centres the motor. I'll just have to re-enter the settings individually. | ||
| wolsty | |||
| | #6 | ||
| Well no other machine I know does it . Razor can confirm his Force machine has it and Ive been testing the latest PVR version, neither are able to take out the Human element, manual store of all positions is the name of the game. Seems like your shelf life has just been reprieved | ||
| There is a very fine line between "hobby" and "mental illness" | |||
| | #7 | ||
My System: Humax IRCI5400z, Sony Digibox, Digilogic Freeview box, 1.1m Triax, Manhattan DiSEqC mount, various cards, Season Interface | In my experience it's the human element which is fallible. Enjoying the extended shelf-life. It's the exposure to microwaves that does it. | ||
| wolsty | |||
| | #8 | ||
| Information Exec Join Date: 01-01-2000 Location: kent
My System: humax 5400z patched to hot 11.1, v box mrk2, 1.1m triax dish, jeager 12" activator .6 lnb, modified pet123 settings ![]() Le grand ordre d'arrangements de Humax | hi wolsty, you were halfway there, when you use the reference option, ermmm ok i will start again. if you choose to go to the reference position (from any other sat) you are in affect putting the mount to the zero position(keeping in mind that you cannot use the reference as a sat name or store it) when you have arrived at this position, and you then use the reset option, this then returns all the HUMAX diqesc 1.2 STORED positions, back to default diqesc 1.2 basic positions, based on 0 zero position,on the mount 0 longtitude. as you know the mount has the diqesc 1.2 positions stored in it, and when you fine tune and then store it, this i believe is stored in the humax.and then adjusts the mounts positions to get the correct one. and then upload an upto date settings file then refind/finetune the sats, depending on what your longtitude is. hope this helps phil | ||
| | #9 | ||
My System: Humax IRCI5400z, Sony Digibox, Digilogic Freeview box, 1.1m Triax, Manhattan DiSEqC mount, various cards, Season Interface | @Phil. Thanks. It confirms what I (eventually) worked out from trial and error. It was the bit about using the reference as a sat name or storing it that had me confused. I'd hoped that, If I could use 5 deg W (which is almost exactly due south of my location) as the named reference satellite, I would be able, automatically, to reset all the others in relation to it. It seems, however, as if I'll have to adjust every satellite position if I move my mount (I'm currently trying to get my arc accurately set up). | ||
| wolsty | |||
| | #10 | ||
My System: humax 5400z patched to hot 11.1, v box mrk2, 1.1m triax dish, jeager 12" activator .6 lnb, modified pet123 settings ![]() Le grand ordre d'arrangements de Humax | hi wolsty, yes if you upload into your humax the settings i posted, (in the zip are a few tutorials that might be of use),using humbox 4.1 or xoak, this will install all the sats in their correct order, and then while setting up your gear, if you choose a channel on that sat, then find the sat and store the position, you will then be able to use the same amount of adjustment to setup the others, for example, when you look for 1W, you will need to go 6deg west of the settings position, then use this for all the rest. i have attached a couple of tutorials that i post on other forums, that might be of some assistance always willing to help phil | ||
| | #11 | ||
My System: Humax IRCI5400z, Sony Digibox, Digilogic Freeview box, 1.1m Triax, Manhattan DiSEqC mount, various cards, Season Interface | Very helpful. Many thanks. I'll be up on the garage roof as soon as it stops raining. | ||
| wolsty | |||
| | #12 | ||
| A bit enthusiastic Join Date: 11-02-2004 Location: Sweden
My System: Giberini 100,Cut Interstar GI-201,CD-80 feedhorn,Humax 8100 PVR,Coship 2300a,18 meters of Antec Superflex 1.6/7.3 ![]() | I have similar problems with my Humax PVR-8100 wich I use with a SG-2100 Diseqc-motor.Cannot get the USALS working either.// | ||
| | #13 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Strange the way some receivers work better with the USALS on the SG-2100 than others, the Hyundai works superbly with the SG-2100, as does the Manhattan, yet others seem to struggle. | ||
| 5400z, humax, reference, satellite |
Similar Threads | ||||
| Digital satellite viewers lose free channels | net1 | Sky Digital (BSkyB) and Astra 28.2 East General | 5 | 16-06-2005 01:22 PM |
| Humax 5100 or Humax 5400z | internetbasic2000 | Digital systems | 9 | 28-05-2004 03:04 PM |
| Add satellite position to Humax? | steford1 | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 7 | 22-01-2004 09:53 PM |
| IFA 2003 Berlin exhibition report | net1 | Digital systems | 0 | 01-10-2003 08:02 PM |
| Will the BBC's satellite dream ever take off? | net1 | Daily Satellite and Broadcast industry News | 0 | 26-06-2003 08:49 PM |
