Connecting motor To Back Of Dish | |
| Regular Member Join Date: 13-06-2005 Location: Teesside (North East England)
My System: Dreambox 500-s, 80cm Dish, 1.2 Compatible Motor |
Hi i currently use a 39cm dish and i know it wont pick all that much up but on the back im unsure how to connect the motor to it. I read the instructions i got with my 1.2 motor but i only have the brackets to connect the motor to the pole, not the motor to the dish. I persume i get some sort of thing to stick on the back of the dish and not drill holes through the dish because then the signal will be ruined, is this right? Plus if i do just stick something to the back of the dish for a mount to be added onto what is this called? thanks, sorry if this is a nooby question but ive not set a motor up before and fancy ago at it myself. | ||
| | #2 | |||
| Member Join Date: 19-02-2004 Location: Co.Kerry Long 9.90 W Lat 52.11 N
My System: Shuttle PC 2.8ghz Sky Star 2 80cm Dish and Moteck SG2100 |
anyway, this guide here is very useful in setting everything up ..well worth a read http://www.satellite-newbie.co.uk/sat1/diseqcinstall.html Also, the dish should have a bracket on the back that will enable it to secure around a pole ... Is this bracket missing ?? The picture in the guide should show how the dish connects to the motor .. any questions, feel free to post | |||
| Super Moderator Join Date: 08-03-2005 Location: J6 M5
Blog Entries: 1 My System: DM7020S ~ DM500s ~ sg2100 ~ Gemini ![]() If he were not a wizard, from head down to the root, you would have got to worry-your DB only boots | A picture is worth a thousand words; can you upload a few photos? Here's mine; what's missing from yours? Picture #2: http://www.satellites.co.uk/satellite/201393-post35.html | ||
| | #5 | |||
| Sky Remote Breaker... Join Date: 05-01-2006 Location: Near Pendle Hill, Lancashire
My System: Mostly gathering dust cos I'm a lazy git. Porty dish face blew off the mount, not too pleased... The Sleepy Hollow pollracle has spoken! |
__________________ I think your car looks funny too...... Proud owner of a satellites.co.uk cap & T-Shirt... Resident KIRBY Vacuum nut... ![]() | |||
