Is my LNB ok,or not (Psecs inside) | |
| Regular Member Join Date: 14-03-2007 Location: 25'40'32S. 28'14'5E
My System: Metabox 3 ; DM500s 0.6m Elsat Lnb Ku-band 1.0m.Dual KU Band LNB 3.1m K-Tronix Mesh Gospell C-band + Kombined KU LNB 4 way Diseq Switch |
Halo Everyone, I have a Gospell C-band Lnb that i currently use. Specs are as follows : Image Rejection 45 dB (Min.) F/D Ratio 0.28~0.42(Adjustable) Cross Pol.lsolatin 20 dB (Typ.) Input Reflector Type Prime Focus Gain Flatness ±4dB(500MHz) Noise Figure 17 °K (Typ.) L.O.Frequency 5.150 GHz Conversion Gain 62dB(Typ.) 55dB(Min.) Input RF Frequency Range 3.4~4.2 GHz L.O.Frequency Stability 1.0MHz @ 25°C ±2.5MHz @-40°C - +60°C Output Frequency Range 950~1750MHz L.O.Phase Noise -60dBc/Hz (1kHz Offset) -85dBc/Hz (10kHz Offset) Output Return Loss 7.5 dB Output Power(at 1dB gain compression) 0dB (Min.) Polarity Switching Voltage V: 11.5V - 14.5V H: 15.8V - 18.0V Output Connector 75ΩF type female D.C. Current Consumption 150 mA (Max.) Operating Temperature -40 ℃~+60 ℃ Is it good quality,or just ok? Thanks! Karis Last edited by karism; 16-05-2007 at 04:27 PM Reason: I suck at spelling | ||
| ASBO Club Member - Persona non grata Join Date: 30-07-2003 Location: Stockholm, Sweden
My System: Metabox 3 ; DM500s 0.6m Elsat Lnb Ku-band 1.0m.Dual KU Band LNB 3.1m K-Tronix Mesh Gospell C-band + Kombined KU LNB 4 way Diseq Switch | Thanks for the reply Bud! Ok,i have another LNb (this one came with the 3m) Which one of the two would you say is better.I have learnt,its not just about the gain,but the noise as well? Item Description LNBF C-Band single cable solution 3.7 - 4.2 GHz Specifications Manufacturer MTI Model Number AC15-2CV Input Frequency Range H: 3.7 - 4.2GHz V: 3.7 - 4.2GHz Output Frequency Range H: 950 - 1450MHz V: 1500 - 2000MHz Connector Type 75Ω Female Connector VSWR 2.5:1 (max) Local Oscillator Frequency H: 5.150GHz V: 5.7GHz Frequency Stability ±1MHz (max) @ room temp. ±2.5MHz (max) @ -40°C ~ +60°C Frequency Phase Noise -75dBc/Hz (typ) @ 1kHz @ room temp -93dBc/Hz (typ) @ 10kHz @ room temp -105dBc/Hz (typ) @ 100kHz @ room temp Conversion Performance at Room Temp Conversion Gain 60dB (min) Gain Flatness ±5dB (max) over operating band ±1.5dB (max) / 36MHz Noise Temperature 25°K(max) Image Rejection 40dB (min) Cross Polarisation 20dB (typ) Power Requirements DC Current Consumption 150mA (max) Operating Voltage 12- 24VDC Thanks! Karis | ||
My System: Metabox 3 ; DM500s 0.6m Elsat Lnb Ku-band 1.0m.Dual KU Band LNB 3.1m K-Tronix Mesh Gospell C-band + Kombined KU LNB 4 way Diseq Switch | Forgot to say. Thanks for giving me some pointers! | ||
| | #5 | ||
| Don't worry about gain with a large dish like that. High gain can also be bad for stronger signals and sometimes you need an attenuator for it. I had C-band LNBs from 45K to 18K and there is some difference but when it comes to C-band the size of the antenna is the king so get the biggest antenna you can afford. | ||
