digialb settings | |
| Member Join Date: 02-03-2007 Location: france
My System: tm 7755 2VA 2CI | hi everyone, may I add quickly what a good bunch of soand so,s youare, question I know abit about basic statelite reception but this problem beats me , I have se up my dish (fixed) to 16 % east ,and for the love of me I cannot get anything but bulgarien channels at this setting, can anybody out there please help me on thi i have an echostar 3000 viaccess ip 2002 80 mtrs dish uni lnb, thankyou for your help norman I have subscribed to digialb packege for premier football next season Last edited by hotkich; 19-05-2007 at 10:26 PM Reason: wrong punch line | ||
| | #2 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | DigitalB is on these frequencies, make sure that you have these in your transponder list. You will need a Conax CAM for the football channels.
__________________ | |||
| The Following User Says Thank You to rolfw For This Useful Post: | hotkich (20-05-2007) |
| Specialist Contributor Join Date: 07-08-2005 Location: west yorkshire, uk
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish | make sure 11092v, 32000, 5/6 and 11449h, 27500, 7/8 is listed on your transponder list otherwise you wont get them | ||
| The Following User Says Thank You to wod For This Useful Post: | hotkich (20-05-2007) |
| | #5 | ||
My System: tm 7755 2VA 2CI | hi Mickha, firstly thank you so much for replying, nice one, yes I have the grey echobx will that make it impossible ,thanks again norman | ||
| | #8 | ||
| Super Moderator Join Date: 10-12-2004
![]() | It depends on the tuner in your Echostar, there was an offer to upgrade the tuner when this problem was first discovered, when DigitAlb altered their S/R to 32000, if you are on 16E and these channels wont scan in then it is a good chance that your tuner can't handle it, but explore other possibilities first. Check if you have too many channels scanned in already. Also try scanning slightly above and below the official frequency, like 11095 V 32000. You should be able to view My Music, which is FTA on 11092 V 32000. If your receiver is one of the ones that can't get the 32000 S/R it might be cheaper to buy a second receiver than update the tuner. | ||
| The Following User Says Thank You to Mickha For This Useful Post: | hotkich (20-05-2007) |
| | #9 | ||
My System: tm 7755 2VA 2CI | hi Mickha, thankyou, I cannot get anwhere near 32000 on my rec, can you please give me a alterative reciever, if I have to pay then so be it would appreciate your guidence on this thankyou again hotkich | ||
| | #10 | ||
![]() | There are lots of good, cheap receivers available, as well as some top end ones. Check out the Technomate range, good value, but also look at the Vantage and Dreambox receivers, it all depends on what you want. There are a few HD receivers available and more due out in the next few months, but if you just want one to last a couple of years try the Technomate 1000 range, you can pick one up very cheaply, get one with a CI slot and a card reader, for future proofing, and the card reader can take a DigitAlb card, once patched. If you want to experiment a bit there are a few Linux based receivers that are currently quite cheap, including a Dreambox 500, but be careful to avoid the clone models. It all depends what you want from your receiver and what you are willing to pay, have a read through the forums on the advantages/disadvantages of various receivers. | ||
| | #13 | ||
![]() | This model is patchable but I don't kmow if it has a built in card reader so you will require a Conax, or multi cam, like the Dragon, to receive DigitAlb. You could always contact the supplier and see if a card reader can be integrated into this model, or go for a cheaper 1500 version. | ||
| | #14 | |||
My System: Sky UK. FTA analogue & digital satellite from 5 fixed dishes (5E/7E/9E/13E/16E /19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | Just for other folks info I have an Echostar IP3000VA - and that one wouldnt go above SR 30000
| | #15 | ||
| Regular Member Join Date: 05-10-2005 Location: UK.
My System: technomate 1500 strong 4375 pace digi box triax 1.1, triax 88cm |
i had that problem with an echostar 3000, the one i have i use in my bedroom, its got to be about 7 years old, it does not take 32000 sr | ||
