Yeehaaa Badr C-band finally here | |
| Regular Member Join Date: 14-03-2007 Location: 25'40'32S. 28'14'5E
My System: Metabox 3 ; DM500s 0.6m Elsat Lnb Ku-band 1.0m.Dual KU Band LNB 3.1m K-Tronix Mesh Gospell C-band + Kombined KU LNB 4 way Diseq Switch | Afternoon Everyone, I finally got Badr c-band today. I have 22 tv channels,and 1 radio. Here is a photo showing the signal rate and so. Karis ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() | ||
| Specialist Contributor Join Date: 07-08-2005 Location: west yorkshire, uk
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish | nice you even got the mbc channels very good for that 3metre dish | ||
My System: Metabox 3 ; DM500s 0.6m Elsat Lnb Ku-band 1.0m.Dual KU Band LNB 3.1m K-Tronix Mesh Gospell C-band + Kombined KU LNB 4 way Diseq Switch | Thanks!I`am so happy. | ||
| | #4 | |||
My System: Sky UK. FTA analogue & digital satellite from 5 fixed dishes (5E/7E/9E/13E/16E /19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | Well done mate - and thanks for letting us know ![]()
__________________ | |||
| | #6 | ||
My System: Metabox 3 ; DM500s 0.6m Elsat Lnb Ku-band 1.0m.Dual KU Band LNB 3.1m K-Tronix Mesh Gospell C-band + Kombined KU LNB 4 way Diseq Switch | Thanks! Was not without the help of the Forum members. Thank you to everyone who helped,even in the smallest way! karis | ||
| | #7 | ||
| Regular Member Join Date: 25-04-2005 Location: Austria
My System: 1,25 Fibostop Jäger Smr 1224 Dual Axsis Echostar Dvr 7000 Monterey 140 Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesch for cband! | Hello! yes,the cband,channels,are very strong,since the new bard is in the orbit,with 1,80 M,Dish,i have realy good signal on all transponder! dont use,normal dialektrikum,use one,made by teflan material,it performce much better,with dialektrikum plate in in,you loose ,a lot of signal,nearly the have,of the stenth reseiving bard! but ,the signal,is so strong,that,you have ,also 50% Signal,when,the dialektrikum plate,is inseide in the lnb! | ||
