LNB Help - 23mm/25mm Collar in Europe | |
| Member Join Date: 22-05-2007 Location: somerset
My System: kvh tracvision lf with pansat 3500sd - used on american motorhome in uk |
Hi We've just imported our American motorhome into the UK. I was told we need to fit a European LNB, so removed the US one only to find the collar is just 23mm (could e 25mm) wide. All European ones Ive seen are 40mm. Can I get a 23/25mm LNB in the UK ? If not, does anyone do a bracket to fit a 40mm LNB to my system? KVH have indicated I need a software/hardware upgrade too - costing £400 - but I want to try the LNB route first. THANKS for your help !! Paul KVH Tracvision SF Auto Locating Dish with Pansat 3500SD Receiver | ||
| Regular Member Join Date: 10-07-2006 Location: Finland
My System: Ku: 2.4m Aerial PFA / Invacom SNF-031, C: 1.2m Aerial PFA / MTI 15k, DM7020-S, DM500S, C-Tech 2100, VBOXII | If you buy an angled MTI LNB (many other possible brands too) and split up the plastic housing (don't touch the white protective cap) you will have a cast-aluminium LNB with 23mm neck. Works fine! | ||
