Dish Setup Questions - what you would go for
Thread Tools Display Modes
Old 22-05-2007   #1
My System: Dreambox 500-s, 80cm Dish, 1.2 Compatible Motor
Ok here is a little questionairre type thing about what setup you would go with. This is created for people to share there views on what system to go with, also allows noobs to get an idea of what setups to go with. all posts are welcome
Dish type
aluminium, steel, fibre or iron?
Ideal Dish size
60cm, 80cm, 85cm, 90cm, 1m or 1m+
What setup
Motorised or multiple lnb?
Receiver type
Technomate, dreambox or other?
Did you find it easy to set up?
Yes, no or i got somebody in to do it
My preference would be steel dish, 80cm, motorised, dreambox 500-s (or 600 or 7000 model if you can afford it), not fully set up yet
this i feel is a very good questionaiire for what some noobs might ask, if anybody has got anything else you think should be included in it then i can add more questions.
Sharkadder is offline   Reply With Quote
Old 22-05-2007   #2
Section Leader
member91040's Avatar
My System: DISH TV,DIRECT DD+, TATA SKY,HATHWAY, NOKIA 9660S, PCI SAT CARD TWINHAN NSS6, PAS7/10, ASIASAT3S, INSAT,INETEL SAT, EUROSTAR, DremBox, & Multi LNB'S
Ok Lots of questions Bro..!
Dish Type : Fiber is Best, For remaning they have there own theroy.
Idle Dish Size : That depends up on you, Max is best for , Max hunting.
Setup : Motorised For Single LNB . Multiple lnb, No need Motor.
Receiver : Cirtal Question, My opnion Dreambox...! and others are also equal together.
Setup: For new hunters crital.
__________________
member91040 is offline   Reply With Quote
Old 23-05-2007   #3
wod
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish
Dish type
smc fibreglass
Ideal Dish size
1m+
What setup
Motorised
Receiver type
dreambox
Yes
My preference would be smc fibreglass dish, 1m, motorised on jaeger 1224 motor , dreambox 8000 but this is a high end setup
Old 23-05-2007   #4
ok im thinking about purchasing an 80cm steel dish, will this make much difference to what i want to pick up to say a fibre one? (astra, utel, hespa, hotbird ec.)
Old 24-05-2007   #5
wod
no an 80cm will be fine for those but you may want to choose a 1metre version instead
[IMG] code is Off
Forum Jump
