Is this dish any good | |
| Regular Member Join Date: 17-05-2007 Location: Leicestershire UK
My System: 65cm dish for Sky+ linked to all rooms, all with own remote and magic eye. Second box in home office (no multi room subscription just use card from main box if needed) 3rd box in bedroom Freeview in other rooms. Free cable in dining room Two 53cm mi |
Hi Is this a good quality dish? _http://www.maplin.co.uk/module.aspx?ITAG=SPEC&ModuleNo=47161&doy=24m5#spec ![]() Or is a Triax TD60 a better option? | ||
| | #2 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | The Triax is much better built, they are pretty flimsy.
__________________ | |||
My System: 65cm dish for Sky+ linked to all rooms, all with own remote and magic eye. Second box in home office (no multi room subscription just use card from main box if needed) 3rd box in bedroom Freeview in other rooms. Free cable in dining room Two 53cm mi | well call me stupid but I went for the Maplin, liked the retro amstrad look | ||
| | #4 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | No, it is fixed with a retaining clip, I use loads of them and they are pretty good for that grade of dish and way more substantial in build and performance than the Fortecstar dishes. At the end of the day though, if it receives what you want to receive, then fine.
