LNB twist position | |
| Regular Member Join Date: 17-05-2007 Location: Leicestershire UK
My System: 65cm dish for Sky+ linked to all rooms, all with own remote and magic eye. Second box in home office (no multi room subscription just use card from main box if needed) 3rd box in bedroom Freeview in other rooms. Free cable in dining room Two 53cm mi |
HI I have fitted my new dish but need some help with the LNB, the Holder on the dish is marked from -20 to +20. what do I line the LNB up with? On the mini dish the markings are from 1-4 and I think its on 2 or 3. Its for picking up Sky and I live in the East midlands. | ||
| Sky Remote Breaker... Join Date: 05-01-2006 Location: Near Pendle Hill, Lancashire
My System: Mostly gathering dust cos I'm a lazy git. Porty dish face blew off the mount, not too pleased... The Sleepy Hollow pollracle has spoken! | Just twist the LNB clockwise until you get the best signal quality on your box...
__________________ I think your car looks funny too...... Proud owner of a satellites.co.uk cap & T-Shirt... Resident KIRBY Vacuum nut... ![]() | ||
My System: 65cm dish for Sky+ linked to all rooms, all with own remote and magic eye. Second box in home office (no multi room subscription just use card from main box if needed) 3rd box in bedroom Freeview in other rooms. Free cable in dining room Two 53cm mi | Is that clockwise facing the dish or from behind the dish? Also roughly what angle up wards should the dish be at? | ||
| | #4 | |||
My System: Mostly gathering dust cos I'm a lazy git. Porty dish face blew off the mount, not too pleased... The Sleepy Hollow pollracle has spoken! | ![]() As for the dish's angle, erm, Ihaven't a clue myself but there are calculators out there, or you could use the old trial and error method...
__________________ I think your car looks funny too...... Proud owner of a satellites.co.uk cap & T-Shirt... Resident KIRBY Vacuum nut... ![]() | |||
| | #5 | ||
My System: 65cm dish for Sky+ linked to all rooms, all with own remote and magic eye. Second box in home office (no multi room subscription just use card from main box if needed) 3rd box in bedroom Freeview in other rooms. Free cable in dining room Two 53cm mi | Thanks | ||
| | #6 | ||
| | #7 | ||
My System: 65cm dish for Sky+ linked to all rooms, all with own remote and magic eye. Second box in home office (no multi room subscription just use card from main box if needed) 3rd box in bedroom Freeview in other rooms. Free cable in dining room Two 53cm mi | Just done a research on the internet, and the "up angle" (for the none technical) of the dish is between 20 and 30 degrees, the further south the higher. | ||
| | #8 | |||
| | #9 | |||
My System: 65cm dish for Sky+ linked to all rooms, all with own remote and magic eye. Second box in home office (no multi room subscription just use card from main box if needed) 3rd box in bedroom Freeview in other rooms. Free cable in dining room Two 53cm mi | This is very useful info from, _sam-radford.me.uk/index.htm | |||
| | #10 | ||
My System: Mostly gathering dust cos I'm a lazy git. Porty dish face blew off the mount, not too pleased... The Sleepy Hollow pollracle has spoken! | Cor, haven't heard his name for a while!!!
| | #11 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | There are hundreds of posts on this forum regarding best ways of aligning dishes, no need to copy from another site. http://www.satellites.co.uk/satellit...stickies-faqs/ gives loads of information. PS. The wet towel alignment method is pretty much outdated now, as most digital receivers have strength and quality metres for adjustment. It used to be effective in the days of analogue pictures, as after roughly aligning the dish to obtain a good picture, you could attenuate the signal enough to cause a sparkly picture, then adjust further to fine tune and regain a clear picture.
__________________ | |||
| | #12 | ||
My System: 65cm dish for Sky+ linked to all rooms, all with own remote and magic eye. Second box in home office (no multi room subscription just use card from main box if needed) 3rd box in bedroom Freeview in other rooms. Free cable in dining room Two 53cm mi | Sorry but I couldnt find any that were as easy to understand. Last edited by Mad Rat; 26-05-2007 at 12:45 AM | ||
