Not sure if my LNB in universal. | |
| Regular Member Join Date: 17-05-2007 Location: Leicestershire UK
My System: 65cm dish for Sky+ linked to all rooms, all with own remote and magic eye. Second box in home office (no multi room subscription just use card from main box if needed) 3rd box in bedroom Freeview in other rooms. Free cable in dining room Two 53cm mi |
After reading the following on Satcure_http://www.satcure.com/tech/lnb.htm#SX1019 I am wondering if the quad LNB I got last year is universal or only for a mini dish Its a Wistron 13671, it came with an adapter to fit any mini dish. It is like this one on Ebay Ebay can anyone help | ||
| | #2 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Yes, they are quad universal, but designed for a minidish. They will work on a normal dish, but are better suited to the minidish. PS, the term universal refers to the frequencies it covers, rather than the design of the LNB or feedhorn, a universal LNB has an upper and lower band, with switching controlled by a 22Khz tone and vertical and horizontal mode, controlled by voltage switching. PPS. I'm not entirely convinced that all LNBs now sold to fit minidishes are specially designed for them, but may be merely adapted with the minidish mounting bracket.
__________________ | |||
My System: 65cm dish for Sky+ linked to all rooms, all with own remote and magic eye. Second box in home office (no multi room subscription just use card from main box if needed) 3rd box in bedroom Freeview in other rooms. Free cable in dining room Two 53cm mi | Dam ![]() need a true universal then. | ||
| | #4 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | It is a true universal, but one supposedly designed for a minidish, if you've already ordered it, give it a try, you should get passable results.
| | #5 | ||
My System: 65cm dish for Sky+ linked to all rooms, all with own remote and magic eye. Second box in home office (no multi room subscription just use card from main box if needed) 3rd box in bedroom Freeview in other rooms. Free cable in dining room Two 53cm mi | already have it on the mini dish, wanted it for the new 60cm round dish. | ||
