X-Line type E lnb
Thread Tools Display Modes
Old 28-05-2007   #1
My System: Phoenix Apollo dish 90cm universal lnb
X-Line type E lnb
Can anyone please tell me if it’s possible to buy a
SMW X-Line type E LNB in the U.K.
I’ve e-mailed SMW direct, but so far have not had a reply.
LENWW is offline   Reply With Quote
Old 28-05-2007   #2
You can buy from me, i have two brand new in box.
I can give you discount.
Likvid is offline   Reply With Quote
Old 28-05-2007   #3
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams
Not aware of any UK suppliers, some German shops still have X-Lines, for example -
http://www.gipsbinden-shop.de/all4sa...merkmalIds=w42
It seems you can choose various LOF's there - 9.75/10.6 is the 'E' type I think
Super LNBs - MY XL800B has a noise figure of 0.65dB and will put some of the later universals to shame. Don't use it now, bit of a nuisance to change the LNB parameters on all my STBs
__________________
Llew is online now   Reply With Quote
The Following User Says Thank You to Llew For This Useful Post:
LENWW (28-05-2007)
Old 28-05-2007   #4
Llew's Avatar
There you go Lenww - an offer from Likvid you can't refuse
__________________
LENWW (28-05-2007)
Old 28-05-2007   #5
Thank you for the reply.
What is the price for one?
And how do I pay?
Regards.
Len.
Old 28-05-2007   #6
And how do I pay?
Regards.
Len.
I can PM you with details as it's not suited to discuss private sales open in the forum
Old 02-06-2007   #7
A sincere thankyou to everyone who answered my question.
I have been using the old Chapparal, (in use since 1993), to move the dish and the Fortec Star to view channels.
The SWM lnb is 10.00/11.00ghz 10.95-11.95 11.95-12.75 therefore of limited use.
A Y connector is in use on the television to take the output of the two rxers, and each rxer is tuned to a different tv channel.
After taping a Universal lnb to the prime focus dish and rxing good video/audio from Astra 2 at 28.2E,
I’ve decided to change my dish and motor, and go for an offset dish with universal lnb, and a diseqc motor.
Old 23-04-2008   #8
Turok's Avatar
My System: 1,25 Fibostop Jäger Smr 1224 Dual Axsis Echostar Dvr 7000 Monterey 140 Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesch for cband!
Hello!
iam also looking for this smw xline lnb type e
i want to use it on my hirschmann polarizer csp 1210,i have testet many polarizers,but my smw lnb that i have xline xl 800 c,seems to have the wrong conector,only the tpye e lnb is compatible to the hirschmann polarizer,does smw,this lnb still have in stock,or are there any newer models outthere,in the meantime,with this round big conector?
Turok is offline   Reply With Quote
Old 24-04-2008   #9
Hello Turok
I threw out my old SWM Xline lnb, as the freq range was not compatible with my digi rxer.
Am now using a universal lnb with a 90cm motorised dish, and a Phoenix rxer.
The results are very good.
Rgds.
Len.
Old 24-04-2008   #10
Turok's Avatar
Hello Lenww!
what is digrxer?
i know,you must change,the lof a little bit lower,to use the full freqency range,of smw lnbs,not every receiver can do this,for expample,the german dbox 2,with orginal betanova soft,here is imposible to use smw lnbs,because,you cant change,the lof.)
here on board,i found a old topic,with the csp 1210 polarizer conected to this type f smw lnb,so this seems the only lnb,where i can conect,to my polarizer..
i have bought other lnb on Ebay ,but it was old only analog very massive 1,1 db
but this i cant use,maybe smw has newer lnbs,in his programm with the same conector then the type f lnb?
i dont know,coz no one here,in german speaking area,sells smw lnbs...
look the links in this topic,then you see why i need this lnb
http://**w.satellites.co.uk/satellit...ibo-tokyo.html
Old 24-04-2008   #11
My System: Skystarcard,Fortec's life time ultra's, MaxPlus 2100's,Dreambox and a Tandberg
Turok
Let me see i think i have one here you can get if for free give me a day to find it.
Ron
Snuffer is offline   Reply With Quote
Old 24-04-2008   #12
Turok's Avatar
thx,
the polarizer you send me,some month ago has exactly the same conector then the csp 120 hirschmann,so i still cant conect it
,i want to make some test with the gregory 1,25 on the turksat eastbeam,but in normal lnb postiition i have no signal,only with polarizer i can do fineadjust!
thx you again,please send pm!
Old 24-04-2008   #13
I have here X-Line XL-1000C
Freq Range 10.7 - 12.75 GHz
Noise Figure 1.0 dB max
With orginal magnetic polarizer. from FUBO DAZ 779
Intrested for you???
Old 24-04-2008   #14
Turok's Avatar
Hi!
sounds great,can you post,some pictures,that i can see the conectors ends?
when both polarizer,and lnb,is compatible,then i can use it on the fibo,!
some polarizers has 2 cables,other 3.is this the ground cable?,the 3. one?
nesersary or not?
Old 25-04-2008   #15
Hello agn from Lenww,
the digi rxer is a Phoenix Apollo.
The reason I changed to a universal lnb was because the swm xline did not cover the frequency range required for my receiver.
Sorry I cannot be more helpful.
Best of luck.
Rgds.
Lenww
[IMG] code is Off
Forum Jump
