Signal Quality not beyond 50%
Thread Tools Display Modes
Old 28-05-2007   #1
Meddy
My System: Six feet C band fixed dish, Opensky 2000X receiver.
I have been trying to align my dish to Intelsat 902 for SABC channels, but the signal quality does not exeed 50 %. Tried to change the wire and the LNB but still the same.
I am in Nairobi, Kenya.
falasha is offline   Reply With Quote
Old 29-05-2007   #2
karism's Avatar
My System: Metabox 3 ; DM500s 0.6m Elsat Lnb Ku-band 1.0m.Dual KU Band LNB 3.1m K-Tronix Mesh Gospell C-band + Kombined KU LNB 4 way Diseq Switch
Halo There!
From what i can see ,your dish needs to be pointed 88deg East ,with a elevation of 58Deg.
What type 3m dish ,and lnb are you using?
Are you sure you have the dish properly aligned?
Karis
karism is offline   Reply With Quote
Old 29-05-2007   #3
rolfw's Avatar
Skew of the LNB is critical to improve quality/signal to noise ratio, also moving the LNB feed in and out of the clamp can improve things.
__________________
Rolf
Donate
Old 30-05-2007   #4
Meddy
Hallo Karism & Rolfw,
Thanks for the quick response,
I have a 6 feet dish and for the Lnb, I need to conform this evening.Tried to skew the lnb but still no improvement on Intelsat 902.
Currently the dish is on Intelsat 906 and some frequencies are ok ( around 68%) while others are still below 50%.
Old 30-05-2007   #5
Section Leader
member91040's Avatar
My System: DISH TV,DIRECT DD+, TATA SKY,HATHWAY, NOKIA 9660S, PCI SAT CARD TWINHAN NSS6, PAS7/10, ASIASAT3S, INSAT,INETEL SAT, EUROSTAR, DremBox, & Multi LNB'S
Bro Try you LNB Depth and Level and f/d .
__________________
member91040 is offline   Reply With Quote
Old 31-05-2007   #6
Meddy
Tried that once but i will do it again.
Karism inquired about my Lnb, well its the standard Eurostar C band lnb. Hope I have answered you well.
Old 31-05-2007   #7
Section Leader
Bro Try polarization too
__________________
Old 31-05-2007   #8
Meddy
sure I will give feed back tomorrow
[IMG] code is Off
Forum Jump
