Newbie> Dish and LNB match help | |
| Member Join Date: 28-05-2007 Location: Stockholm, Sweden
My System: Triax 110cm dish Inverto Universal Quad LNB Pace 2600 C1 and DS430N Digiboxes |
Hello. I am planning to pair a Gibertini 120 with a Invacom Twin LNB in a 2d fringe area (Stockholm). My question is, is it better to get the Invacom with integrated feedhorn (TWH-031) or the one without (TWF-031). If the one without feedhorn is better which feedhorn should I use? Does one come with the dish? Btw, my digibox is a Pace 2600 C1. Thanks for your help. | ||
| Specialist Contributor Join Date: 23-07-2005 Location: S.Wales
My System: 1.2M & 55cm Gregorian Dish`s, 1.5m Gibertini on a Jaeger 1224 H-H motor. Dreambox 7025 200gb HD, Vbox-II. SS2 Card. | Gibertini do make a feed, there are subjects covered here, do a search mate. I have also read some one using a channel master feed for a gib dish.
__________________ Roiders are like the sun, big, orange, and never stare directly at them | ||
My System: Triax 110cm dish Inverto Universal Quad LNB Pace 2600 C1 and DS430N Digiboxes | OK, I did a search as told and to be honest I'm not that much wiser. Some people are slagging off Gibertini and also saying it doesn't match with an Invacom LNB (something to do with f/d). I am a complete novice at this and didn't know what a LNB was a couple of days ago. Let me rephrase the question: I'm in Stockholm looking to receive 2d. I've already purchased a 2nd hand Pace 2600 C1 digibox and now need a dish + accessories. The maximum size dish I'm looking at is 1.2m. Can someone please recommend the following> Dish (1.2m) LNB (with or without integrated feedhorn) Feedhorn (if not integrated) Anything else needed? ![]() By the way, if any of you are in the Stockholm area and are interested in installing the system for me then I'm willing to pay the going rates. Thanks for the help. | ||
My System: 1.2M & 55cm Gregorian Dish`s, 1.5m Gibertini on a Jaeger 1224 H-H motor. Dreambox 7025 200gb HD, Vbox-II. SS2 Card. | Go for a Channel master/Andrews dish, with matching feed horn. An Invacom lnb will work great with that set up. Even better if you can get one, go for a 1.2m fibo Gregorian dish. But there not produced any more.
| The Following User Says Thank You to CROSSBONES For This Useful Post: | rellstar (30-05-2007) |
