90cm+ the solution to my indoor dish problem? | |
| Regular Member Join Date: 24-06-2004
I'm not allowed to put a dish on my flat, although we do have a communal dish pointed to 28 East. However I'm looking for 13 and 19 East and have tried getting these using my Maplin 40cm dish indoor (from their satellite kit). So far I've been unable to get anything. This is especially disappointing considering my window points exactly south. I've also checked some of the threads in this forum on the topic - but I'm still not getting anything. So I was wondering - would a bigger dish - say 90cm+ - guarantee results, or are some windows just completely impenetrable? | ||
| Specialist Contributor Join Date: 07-08-2005 Location: west yorkshire, uk
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish | the 40cm dish would have had no chance as the signal reduces but is receivable through glass so you need a larger dish to compensate for some loss of signal | ||
| The Following User Says Thank You to wod For This Useful Post: | blackninja (04-06-2007) |
| | #3 | |||
| Member Join Date: 27-05-2007 Location: scotland
My System: Technotrend 3200, Triax 80cm dish, Pace 2600C1, Thomson DSI 8210, Raven 60cm dish. Skyline DSR 6000, Stab motor. |
I suggest you mount the dish on your window ledge if possible or just outside the window. | |||
| The Following User Says Thank You to thedavid For This Useful Post: | blackninja (04-06-2007) |
| | #4 | |||
I might buy Maplin's 90cm dish, so at least I can return it if it doesn't work. Thanks. | |||
| | #5 | |||
| Member Join Date: 19-03-2007 Location: East Anglia
My System: TM-1500Ci+ Super - 1.5m Centre feed - 0.3dB Lnb |
Some 15 years ago a 60cm dish was enough to get Astra for me... Remember, an offset dish will need to be lower to the floor than a prime focus, I found that too near the window was not good. I ended up with the dish about 2 foot off the floor and about 5 foot away from the window... I think you maybe too close and hence blocking much of the signal... You may wanna try again.. | |||
| | #7 | |||
| Sky Remote Breaker... Join Date: 05-01-2006 Location: Near Pendle Hill, Lancashire
My System: Mostly gathering dust cos I'm a lazy git. Porty dish face blew off the mount, not too pleased... The Sleepy Hollow pollracle has spoken! | You must be to have a dish that big indoors!!!
__________________ I think your car looks funny too...... Proud owner of a satellites.co.uk cap & T-Shirt... Resident KIRBY Vacuum nut... ![]() | |||
