Will this dish work?
Thread Tools Display Modes
Old 05-06-2007   #1
My System: PLAZA ST100 FTA, 3 mini dishes, Zone 2 dish on a motor, TM 1000D
Hi, I have been told in the past that to get 26e the minimum is a 1m. Today I noticed the 85cm Fracarro penta claims to be better than a 1 meter conventional dish. Is this true or not. If it is it should work right?
Thanks for reading
modman is offline   Reply With Quote
Old 05-06-2007   #2
My System: technomate 1500 strong 4375 pace digi box triax 1.1, triax 88cm
modman,
im not sure about the fracarro, but i use an 88cm triax from hartlepool in the northeast for 26e badr. For the mbc i get an average of 55% to 62% and one tv somewhere around 60% to 64%. I reckon down your area you should get it ok, try and get the one tv first 12130 v 27500 I have a pole in the back garden and to get the signal i use a tv next to the dish to get the signal up, even on the ground mbc is awkward to get but from where you are based you will possibly get the signal a little bit better even if you are up a height
johnwilliam1 is offline   Reply With Quote
The Following User Says Thank You to johnwilliam1 For This Useful Post:
modman (06-06-2007)
Old 05-06-2007   #3
thanks for that advice, Im thinking of buying one soon but not at the moment if I do id like to get this one because it seems like I should get mbc's.
Old 06-06-2007   #4
One more thing are the 85 cm transparent dishes good enough to get the mbc's. The problem I have is its going in the garden and must look ok to other people in my house (not too big). As above the Triax 88cm gets them so will 3cm be a significant loss?
Old 06-06-2007   #5
They praise the dish on Italian forums so i guess it works pretty good.
Likvid is offline   Reply With Quote
Old 06-06-2007   #6
so Likvid, do they praise the Fracarro Penta or the transparent dish?
Old 06-06-2007   #7
rolfw's Avatar
I guess that if they compare the Fracarro to the standard garbage which are often served up as 1m dishes, it probably is good, but I seriously doubt that it would outperform a quality 1m.
__________________
Rolf
Donate
Old 06-06-2007   #8
Thats what I was thinking it sounds overhyped
Old 06-06-2007   #9
Fracarro dishes.
Old 06-06-2007   #10
There has been a thread about these dishes earlier on this forum and their secret is that they can make larger dish look smaller by cutting the four corners.
The dish have it's major gain in the centre of the dish and it fades the further you go to the edges, by making the dish bigger and and therefore getting a larger area in the center and by cutting four corners of the edges the dish look smaller but performs like a larger dish.
The Following User Says Thank You to Likvid For This Useful Post:
modman (06-06-2007)
Old 06-06-2007   #11
Site administrator
Analoguesat's Avatar
My System: Sky UK. FTA analogue & digital satellite from 5 fixed dishes (5E/7E/9E/13E/16E /19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S
They cut the corners off a circle?????
__________________
Analogue forever!
RIP BBC2 analogue on all Scottish Borders transmitters, switched off 0031GMT November 6th 2008
Final analogue switch off from all Scottish Borders transmitters - BBC1 ITV C4 & C5 - 0010GMT November 20th 2008.
Old 06-06-2007   #12
We should start a business. You buy the dishes, ill cut the corners and double the price
Old 06-06-2007   #13
wod
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish
surprised it works at all being that shape , surely only good for strong signals from astra 1/2, hotbird, 5west etc
[IMG] code is Off
Forum Jump
