F connectors | |
| Regular Member Join Date: 04-09-2004 Location: Hounslow
My System: Echostar AD3600IPVA, White Inverto 0.3db LNB, Fibo Gregorian 1.2mtr, Skystar 2 |
Hi, Anybody got a few spare good quality F-Connectors for RG6 cable., even snap-seal will do. please pm me. Thanks | ||
| Regular Member Join Date: 13-06-2005 Location: Teesside (North East England)
My System: Dreambox 500-s, 80cm Dish, 1.2 Compatible Motor | dude go down your local shop and get some, they are only a few quid, some shops i know which might sell them on the cheap are: wilkinsons and boyes (if you have any of them stores, they are only about £1) if failing that go down to your nearest maplin store, they sell them for about £2.50 and you need the female f type connectors. hope that helps, it would cost more for somebody to deliver them than for you to buy them yourself. | ||
| | #3 | |||
| Regular Member Join Date: 21-04-2007 Location: nottingham
My System: chaparral montery 40 fully loaded ehcostar ad3600ipvia 3 dishes zone 2 / 1 mt motorized / 2.3 m motorized |
ive seen f plugs and barrel connectors for f plugs but never a femail type f connector ??? | |||
My System: Dreambox 500-s, 80cm Dish, 1.2 Compatible Motor | sorry i meant male end is what you need, you can find out about some of there here: http://www.electronix.com/catalog/default.php/cPath/11 over in the uk we use male and female connectors (as you should know being from notts) and just like coaxial connectors the F type ones also have male and female ends. its the male type you need i think i got it wrong but that site tells you the connection you need | ||
