Edision 2100 | |
| Member Join Date: 10-12-2005 Location: mt
My System: none |
Hi does anyone have an Edision 2100 FTA receiver? I am having some problems to set it up.. Basically after mounting everything, (pole vertical, dish aligned with rotator arm, angles etc.) I chose astra from the receiver menu on usals (having inputed lat long) and moved the whole thing around to get astra. however when i try to move to hotbird it is way far off and no amount of east-west movement from the receiver (using diseqc 1.2 commands) will get me hotbird... I have a Superjack jaeger DG-120 motor with a 120cm dish. Now I am going to try to mount rotate everything in line with the sun at transit tomorrow.. so as to align with true south. regards | ||
| Amo Amas Amant Admin Join Date: 18-11-2004 Location: NW England (Siberia)
That will only help if 1deg West is your true south satellite but since your profile indicates simply mt for your location who can say?
__________________ War does not determine who is right, it determines who is left! Formerly toppervte33h whose six pack has turned into a keg Help support this web site by making a donation Or use other options to help support Sats UK Show Your Support by clicking the button ![]() Thank you. Freddie Flintoff is back | ||
