Help. Motorised and fixed dish on one receiver?
Old 07-06-2007   #1
Robbo's Avatar
Real name: Mark
I have a motorised dish looking east, and have just added a fixed dish pointing at Hispasat. Will a diseqc 2 way switch work ok between the two?
I have done a search could not see a reply to this specific setup.
Cheers.
Old 07-06-2007   #2
rolfw's Avatar
Real name: Rolf
Have a look at York's thread at the top of the Sticky section.
Rolf
Old 07-06-2007   #3
Robbo's Avatar
Real name: Mark
Thanks Rolfw- I have looked at that already, but he has two motors. I was wondering if anyone had just one motor and one fixed dish and didn't have to alternate positions in order to get the diseqc 1.2/USALS to work.
Old 07-06-2007   #4
rolfw's Avatar
Real name: Rolf
What you have is a more simple version, so you may not have similar problems.
Rolf
Old 07-06-2007   #5
Mentally unstable.
Yorks's Avatar
My System: Pretend to know what I'm doing. Only the clever ones rumble me.
...Now he's joined a sat forum, And boy does he borem, When the hind legs off a donkey - he talks
Hi Robbo71,
It should work, but it depends on the compatibility of your equipment. Before deciding to motorize my second dish (mine too was static on Hispasat), I used a manual A/B switch to switch between the two. If you use TMEditor you can turn off the diSEqC positioner setting for Hispasat (this is only a global command on the receiver), and leave the rest on 1.2 or USALS. That way if you forget to flick the switch before selecting Hispasat , the motorised dish won't go off on it's travels.
If you are feeling brave then you can risk less than a tenner on a DiSEqC switch
Regards,
Yorks.
Life's a bitch ................ and then there's S*y (No change there then)
Wurdoch ist ein Manker. (Mank being a city in the
Austrian Alpine foreland)
Yorks is offline   Reply With Quote
The Following User Says Thank You to Yorks For This Useful Post:
Robbo (08-06-2007)
Old 07-06-2007   #6
Robbo's Avatar
Real name: Mark
Originally Posted by Yorks View Post
Hi Robbo71,
Regards,
Yorks.
Thanks Yorks.
On my receiver it looks like I can disable Diseqc positioning locally just for Hispasat. I'm using it at the moment, I have a manual switch- a small spanner behind the box so I can swap feeds..
For a tenner, yes I think it's work a try with the Diseqc switch.
regards.
Old 07-06-2007   #7
Mentally unstable.
Yorks's Avatar
If you do decide to splash out, I'll give you some help configuring your settings, if you have any problems.
Regards,
Yorks.
Robbo (07-06-2007)
Old 08-06-2007   #8
Robbo's Avatar
Real name: Mark
Yorks- you were right, the motor settings are global on the TM1000D, found this out when I tried to go back to use the motor and nothing happened. TMEditor did the trick though.
This must surely be a bug in the firmware? On my Fortec Beta the motor controls are independent for every satellite.
So thanks once again for the info.
Old 08-06-2007   #9
Mentally unstable.
Yorks's Avatar
Hi Robbo71,
I think it's just something that they didn't think of at the time.
  1. If you have a DiSEqC motor - you use 1.2 or USALS.
  2. If you have static dishes/multi lnb's - you use 1.0 or 1.1
Simple!
Why on earth should anybody need to use both?
If only life was that simple .
Oh.... by the way, if you change your DiSEqc positioner settings on your receiver for any reason, it will change the lot again and you will need to edit Hispasat to 'OFF' again on the PC.
Regards,
Yorks.
Old 08-06-2007   #10
Robbo's Avatar
Real name: Mark
Either that or knock down next doors house
Old 08-06-2007   #11
My System: Dreambox 8000 HD PVR, 80cm Dish, 1.2 Compatible Motor, Quad LNB, Porty TV, Yamaha RX-V765 Amplifier, Tannoy Mercury FC Centre Speaker, 2 x Tannoy F1 Custom Speakers, 2 x Tannoy FR Custom Speakers, EPOS ELS Sub Woofer
robbo i have the same problem lol where my bedroom window is i can only get the eastern ones i have notice and to get any of the western one like hespasat because im after that 1 id have to put a dish around the back. Im thinking about saying stuff it and stick the dish pointing over the roof (thats if the installation guy will do it) then i can get them all.
But next door yeah all they need to do is put it on the side of there house as 1 of there walls faces every satellte. I know its risky putting it on the roof but hey lifes 2 short to be peeing around with 2 or 3 dishes on a house for me and plus the neighbours would want to know what im up 2.
Sharkadder is offline   Reply With Quote
Old 08-06-2007   #12
Robbo's Avatar
Real name: Mark
Yeah,one of my other ideas was to mount my motor on a west facing wall looking over the roof. The slope and length of my roof would have allowed me to get up to 45W, depending on how high I put it.
I ditched this idea though as I didn't want to shell out for expensive bracketry,it would have looked ugly and I'm scared of heights.
I had a 90cm dish lying around as I bought the Maplin kit, so I cobbled up a ground mount and stuck it behind some trees in my back garden. It can hardly be seen from the garden.Finally found a hiding place for my 90cm dish
Old 21-06-2007   #13
Robbo's Avatar
Real name: Mark
Finally received a 4-way diseqc switch, connected it all up with my motor on LNB1 i/p and my fixed dish on LNB2 i/p. Set up my receiver using TMEditor with the sats I want on the motor set to USALS and diseqc 1 position 1, and my fixed dish set to USALS off and diseqc 1 position2.
Guess what!!
Not a blinking sausage. The motor won't move and the switch won't switch. No signals at all either.
The switch will only work when I physically remove the motor from the circuit.
The switch I have is a ES41DS from Eurostar. My motor is a Fortec Star branded STAB HH90 motor.
Anyone got any ideas please?
Yorks?
Old 21-06-2007   #14
Mentally unstable.
Yorks's Avatar
Hi Robbo71,
Have you tried the Motor on LNB2. I would say your first priority is to try to get your motorised dish working through the switch. It could be a compatibility issue.
You can also try switching receiver ON/OFF/ON at rear, after installing and configuring switch for motor. If that works, connect and configure static dish cable and repeat ON/OFF/ON. (I would recommend that you always cut power when connecting/disconnecting coax).
I am using a 'Global' 2 way switch, which worked OK with my Fortec Star FS2100 motor, before adding a second motorised dish.
I have read where TM users have had problems with one brand of switch, and success with another. 'Emitor' 4 way was a problem for one guy, but I think it can all depend on individual equipment.
Let me know how it goes.
Regards,
Yorks.
Old 21-06-2007   #15
Robbo's Avatar
Real name: Mark
Thanks Yorks.
I have already tried conecting the motor to i/p 2 on the switch
and I always switch off the receiver anyway.
I think my switch must be incompatible. I've disconnected the motor at the moment I think it will stick to just using the switch, until I can find a switch that will work with the motor.
Cheers
Robbo.
Old 21-06-2007   #16
Mentally unstable.
Yorks's Avatar
OK m8
The Global 2 way seems to be as popular as any for these weird configs - but please don't hold me to it, if it doesn't work for you.
Regards,
Yorks.
Old 29-06-2007   #17
Robbo's Avatar
Real name: Mark
Finally got it working perfectly!
Update- I have finally got a motorised dish and a fixed dish working together on a single receiver.
The receiver is connected straight to the motor (REC).
The motor (LNB) then goes to the Diseqc switch output.
The LNB of the fixed dish connects to LNB i/p 2 of the switch.
The LNB of the motorised dish goes to LNB i/p 1 of the switch.
Basically, putting the motor first and then the diseqc switch next and then the LNBs works.
Putting the diseqc switch first doesn't
No problems at all, the motor moves straight away without any hassles, and the switch switches.
On the Technomate the motorised settings were set to USALS for the sats on the motor, with the diseqc 1.0 set to 1. For the sat on the fixed dish Motor control was set to off with diseqc 1.0 set to 2. This was done using TMEditor, thanks to Yorks.
Old 29-06-2007   #18
Mentally unstable.
Yorks's Avatar
Great news Robbo71.
So just to clarify - do you have a single cable connecting your receiver to your motor (REC on motor), and then the DiSEqC switch connected to your motor's lnb terminal (LNB on motor) and a cable running to each LNB from the DiSEqC switch?
Regards,
Yorks.
Old 29-06-2007   #19
Robbo's Avatar
Real name: Mark
Yes Yorks, exactly what I've done.
I think it works because the DiSEqC motor must be completely ignoring any DiSEqC 1.0 commands and letting them straight through.
The economy DiSEqC 1.0 switch however when connected first was possibly trying to interpret DiSEqC 1.2 commands, failing miserably, and not bothering to pass the info onto something that would. Then getting its knickers in a twist and ignoring everything else it was told after that.
I was going to post up a wiring diagram, but for some reason it is not possible for me to post attachments at the moment
Last edited by Robbo; 29-06-2007 at 11:24 PM. Reason: dIseQc!DiSeQc!DiIsecQ!DiSEqC
Old 29-06-2007   #20
Mentally unstable.
Yorks's Avatar
Well done m8. Where there's a will there's a way, (usually).
Regards,
Yorks.
Old 29-06-2007   #21
Robbo's Avatar
Real name: Mark
Wiring Diagram
Wiring Diagram:-
Help. Motorised and fixed dish on one receiver?-dish2-jpg
The Following 3 Users Say Thank You to Robbo For This Useful Post:
Artist 2004 (05-07-2007), NunoV (11-10-2009), Yorks (02-07-2007)
Old 19-10-2008   #22
saki's Avatar
I got channel master 1.2m motorised with echostar 3600, which is getting replaced soon with a dreambox and a vbox.
Reading this got me thinking
I have an additional dish with 2 lnb's unconnected( was there from previos owners ).
Can I use this somehow or?
The dish is there with astra and hotbird set and working.
Any thoughts?
saki is offline   Reply With Quote
Old 20-10-2008   #23
Robbo's Avatar
Real name: Mark
Yep, that should work OK, if not you haven't lost much.
Wire from the receiver to the V-box, then out of the V-box to a Diseqc switch, and then to the LNBs.
When selecting 13E and 19E the dish may still move, but you will get an immediate signal, rather than waiting for the dish to get there.
In the Dreambox, I imagine you could stop the motor moving when you selected 13E or 19E, but on the TMs, it is more dificult.
Old 21-10-2008   #24
saki's Avatar
cool, once I get all the stuff I'll try.
Old 26-04-2009   #25
private4587's Avatar
My System: Motorised dish with twin LNB, fixed dish with quad LNB Dreambox 800HD and TM9100 receivers Pentium 4
Hi very good stuff and very useful, My problem is similar but what I want to do is to use a motorised and static dishes to two receivers, would puttin a two to one connection for motor connection cause loss of signal.
private4587 is offline   Reply With Quote
dish, fixed, motorised, receiver
[IMG] code is Off
