Thai TV Channel setup help | |
| Member Join Date: 28-05-2007 Location: 51.47699N -0.276E - Richmond, UK
My System: Newbie to this whole thing trying to setup a multi LNB dish pointing towards Astra 2 (Sky Digital) and Hotbird from 51.47699N -0.276E. Please help. |
I am trying to pick up Thai TV Channel from Hotbird through my digibox. My dish is aligned correctly (I believe at Network ID 013e, Transport Steam 1450). The signal strength is full and the signal quality is half way. Ive added the channels but for some reason when I choose the channel to watch, it says no sat signal is being received. Is there something i'm doing wrong? I'm a newbie here so any suggestions would be appreciated. Thanks | ||
| | #2 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | So are you saying that if you go into Add Channels on the digibox and put in 12207, 27500 and 3/4, that it finds the channel and you are able to save it using the yellow button?
__________________ | |||
My System: Newbie to this whole thing trying to setup a multi LNB dish pointing towards Astra 2 (Sky Digital) and Hotbird from 51.47699N -0.276E. Please help. | yes it adds the channel and i a able to save it to other channels. I choose the channel by pressing the tv guide or services button then click on other channels. The Thai Channel is listed there so I select it. But nothing shows up. Just satellite signal not being received. THe only reason I'm using the sky digibox is because that is the only channel my mom wants to watch. There is no other channel i am interested in, which is why i'm not buying another receiver. | ||
