Best choice for motor system on a 85cm penta dish to use at low elevations
Thread Tools Display Modes
Old 09-06-2007   #1
Ole Roenne's Avatar
My System: 85 cm dish FTA receiver
Wink Best choice for motor system on a 85cm penta dish to use at low elevations
I am looking into expanding/upgrading my sat system and get it motorrized.
I live in Iceland, Reykjavik, so a dish setup often requeries a low elevation angle, down to approx. 3 degrees.
What motor system will help me acomplish that best ?. and what would you recommend ?.
Best regards.
Ole
Ole Roenne is offline   Reply With Quote
Old 09-06-2007   #2
rolfw's Avatar
Everything from where you are is relatively low on the horizon, what sized dish are you going to use and is it in an exposed location??
__________________
Rolf
Donate
Old 10-06-2007   #3
Ole Roenne's Avatar
Smile Dish size etc.
Hello,
Thanks for the response.
I will be using a ferraco penta 85 dish with a gain of 39 db.
The dish will be placed on a balcone , which will provide some shelter from wind and rain. There will of course be a line of sigth to the positions I want to see.
Best regards
Ole
Old 14-06-2007   #4
Ole Roenne's Avatar
Question Has any one any ideas.
Hallo, has any one some idea of what I should go for,
I am wating with great exictement.
Best regards
Ole
Old 14-06-2007   #5
rolfw's Avatar
sorry should have read you post better.
The Penta dish will be fine on a DiseqC motor, something like the Moteck SG-2100.
__________________
Rolf
Donate
Old 15-06-2007   #6
Ole Roenne's Avatar
Exclamation Hallo, again.
I see that that you own such a motor, so you must know what you are talking about.
But what does it mean when it in the specification for the motech says,
Elevation Angle10~75
Doesn't that mean that I can't use it for angles less than 10 ??.
Thanks again
Ole
Old 15-06-2007   #7
My System: My system:Receiver-Sky Sat 9900FTA+emu;Ferguson FX-6600CR/OCTAGON SF318;LNB-Sky Sat, universal, 0,2dB;1.2m offset dish ;Diseqc 1,2 +USALS Moteck2100A motor; 1,2m parabola+0,3dB Inverto @ H-H Strong SRT DM 2100
Thanks again
Ole
Don't trouble Ole, your location latitude is 64o 8', Moteck scale - 15-65o and will point all the satellites in the range 45W(Pas 1R, 1,14o elevation) up to abb. 90E(YAMAL 201, 0,68o elevation). Look at this:
http://www.satsig.net/22-deg-offset-dish.htm, and download "Satellite Antenna Alignment " from http://www.al-soft.com/saa/saa.exe
You need bigger dish if Hotbird 13E is interest to you.
popovp is offline   Reply With Quote
Old 15-06-2007   #8
rolfw's Avatar
Yes, as popovp says, the elevation they quote is the elevation required for the satellite at the top of the arc, this being I think about 26 degrees on the Moteck scale, or you can actually set it to your latitude on the latitude scale.
__________________
Rolf
Donate
Old 16-06-2007   #9
Ole Roenne's Avatar
Talking Thanks
Hallo again.
Thank you both(rolw and popovp) for clearifing the meaning of that spec. ,
I will over the summer install the equipment and keep you posted on how every thing goes.
Thank again.
[IMG] code is Off
Forum Jump
