Safety Guidelines for Dish InstallationInformation exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| | #1 | |||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. |
Thought we'd better give some guidelines on what should and shouldn't be done safety wise. Here's a little poem, originally posted by York
| The Following 2 Users Say Thank You to rolfw For This Useful Post: | Analoguesat (11-06-2007), sparky2305 (14-09-2008) |
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | And lets add never ever do any work on you dish unless you have 100% safe access to it and if you are up a ladder make sure there is someone around just in case you fall off. A small dish (or aerial) can act just like a sail if the wind catches it in the wrong way, and even a small dish will have you off a ladder if the wind gets behind it whilst you are off balance. Always, always, think safety first. Its really not worth hurting yourself just for the sake of putting that new dish up instead of waiting a few days! | ||
| | #3 | |||
| Mentally unstable. Join Date: 27-03-2005 Location: S. Yorks
My System: Pretend to know what I'm doing. Only the clever ones rumble me. ![]() ...Now he's joined a sat forum, And boy does he borem, When the hind legs off a donkey - he talks |
| Life's a bitch ................ and then there's S*y (No change there then) Wurdoch ist ein Manker. (Mank being a city in the Austrian Alpine foreland) ![]() | ||||
| Member Join Date: 05-01-2006 Location: Atherstone, Nr. B'ham/Cov.
My System: Freeview, BT Total Broadband, BT Broadband Talk | Ladies and gents, think safety first And don't go up when the weather's worst. Wait a while and sit inside Until the strong wind does subside. Make sure your ladder, it is steady And make sure your friend is beside you and ready Because if you should fall and land on your ass Your friend will be there thinking "My, what a prat." The smallest of dishes can act as a sail so remember this rule and you'll never fail: "If it's stormy outside, don't be a tit, wait around inside 'til its blown over a bit." That's my effort! | ||
| | #5 | ||
| Member Join Date: 19-12-2008 Location: South West Birminham
My System: Fortec Star Innovation Receiver 80cm dish (Maplin HD kit with motor) | Since you are probably drilling holes in a wall why not drill your first one roughly 3/4 of the way up and fit a shield anchor with an eye. Then tie your ladder into the wall with that, using nylon rope. You will probably need to get at your dish again and you'll be glad you did. I also regard a ladder stand-off as an essential accessory. | ||
| | #6 | |||
| lifes not a practice run Join Date: 27-09-2006 Location: torfaen south wales
My System: Technomate diseq 1500ci+ and Humax Foxsat HD Acer Aspire 5315 |
![]() ![]() ![]() cheers dave | |||
| | #7 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | An eyebolt with sleeve anchor is I think what NickH is describing you can use one to tie your ladder to the wall and then rope yourself to the top rung. A ladder stand off will add to the stability, I use the microlite, but a cheaper standard standoff will suffice. Better still would be to hire a tower, then the whole thing will be like working at ground level, makes for an easy life. | ||
| The Following User Says Thank You to rolfw For This Useful Post: | nickH (04-01-2009) |
| | #9 | ||
| Member Join Date: 29-05-2008 Location: Dubai, UAE
My System: Sony Bravia 40 inches model KLV-40V400A full HD, Samsung Digital Home Cinema System model HT-Z315, Dreambox HD 800, Nilesat, Hotbird, Nintendo Wii, Xbox 360, Aztech ADSL2+ Wireless router 1Mbps | its easier know to remember the tips | ||
| dish, guidelines, installation, safety |
