What is Left & Right polarization & how to receiver them? | |
| Member Join Date: 14-12-2005 Location: Sri Lanka
My System: Accessing NSS6 satellite Having P4 2.8GHz computer |
What is Left & Right polarization & how to receiver them? Can I receiver them from the same LNB I'm using to get V & H polorizations? If it is, how? | ||
| | #2 | |||
My System: Sky UK. FTA analogue & digital satellite from 5 fixed dishes (5E/7E/9E/13E/16E /19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | Left hand circular and right hand circular polarisation. No you cant use a normal H/V lnb - you need a circular polarity lnb and a receiver that can cope with circ polarity too. (Actually to be strictly accurate yes you can use the wrong type lnb although the results are spectacularly poor! Ive tried it! )
__________________ | |||
My System: Accessing NSS6 satellite Having P4 2.8GHz computer | | ||
| | #5 | ||
| Section Leader Join Date: 07-07-2006 Location: INDIA
My System: DISH TV,DIRECT DD+, TATA SKY,HATHWAY, NOKIA 9660S, PCI SAT CARD TWINHAN NSS6, PAS7/10, ASIASAT3S, INSAT,INETEL SAT, EUROSTAR, DremBox, & Multi LNB'S | Kav Bro , yes you can receive on the same LNB, Put a flat Teflon disc in the feedhorn mouth , Then you can able to receive circular signal .
| | #7 | ||
My System: DISH TV,DIRECT DD+, TATA SKY,HATHWAY, NOKIA 9660S, PCI SAT CARD TWINHAN NSS6, PAS7/10, ASIASAT3S, INSAT,INETEL SAT, EUROSTAR, DremBox, & Multi LNB'S | You can easley buy in the market or use glass flat disc.
| | #8 | ||
My System: Accessing NSS6 satellite Having P4 2.8GHz computer | ok got a disc. Now how should I set the transpondr to search. In the receiver I have only Vertical &Horizontal to select. (this is not a blind scan receiver) | ||
| | #9 | ||
My System: DISH TV,DIRECT DD+, TATA SKY,HATHWAY, NOKIA 9660S, PCI SAT CARD TWINHAN NSS6, PAS7/10, ASIASAT3S, INSAT,INETEL SAT, EUROSTAR, DremBox, & Multi LNB'S | Put you teflon disc in feedhorn mouth, and try to auto search, Apply H & V as L & R .
| | #10 | ||
| ASBO Club Member - Persona non grata Join Date: 18-06-2007 Location: BANGALORE INDIA
My System: I HAVE COLORDO RECEVER WITH 6 PRIME FOCUS FEET SOLID SHEET ANTENNA. | Please Guide me How can I press auto search when I have not yet found the Satellite. | ||
| | #11 | ||
My System: DISH TV,DIRECT DD+, TATA SKY,HATHWAY, NOKIA 9660S, PCI SAT CARD TWINHAN NSS6, PAS7/10, ASIASAT3S, INSAT,INETEL SAT, EUROSTAR, DremBox, & Multi LNB'S | Ohoo Before starting you are asking from the end point. Ok No prob bro, Submit your Lat & Log, we will provide you AZ & EL, Soo that you can tune it properly, if not refer old threads. You can do it by your own.
