Noise from DiseqC motor
Thread Tools Display Modes
Old 19-06-2007   #1
dasteelman's Avatar
My System: 85cm transparent dish 0.2db lnb titanium wf100 cable dreambox500s technomate 9100 linux Eaglebox UK nds card
hi again guys,
I have a diseqc motor, the typical 40 pound type.
works like a dream, no problems. However I have a minor problem.
My setup is situated on the wall of my downstairs flat. Although the sound of the motor is not a problem for me, the neighbour upstairs has noted this.
My question is this....is there anyay I can reduce/absorb the sound of the motor? I was thinking of even wrapping sponge around it??
ooh and before anyone suggests....moving the dish somewhere else is out of the question.
Thanks in advance guys
dasteelman is offline   Reply With Quote
Old 19-06-2007   #2
My System: Dreambox 500-s, 80cm Dish, 1.2 Compatible Motor
lol i have the same problem with the noise but my neighbours arn't complaining about it just its abit loud, the only decent thing about noise is you can hear how far its turned. seems to me like you have same motor also lol this is strange you have same sort of dish as me, same sort of receiver, same sort of motor and live near me lol.
Anyways i dont think wrapping something around it will help because it has to turn according to what stellite you are on, maybe you could enclose the part that turns in some sort of sound proof box with a circular hole in the top to allow the pole to go through.
It could work but abit tricky to do cos you would have to take it all apart just to enclose it that way. Another option is to buy a new low noise motor, but what i said is a suggestion which could work with abit of effort.
Sharkadder is offline   Reply With Quote
Old 19-06-2007   #3
rolfw's Avatar
You can fill the mast with sand to sound deaden it, stick adhesive foam on the back of the dish will also prevent some of the reverberation and as you say, a thick foam jacket over the motor will help.
You may also be able to wrap the wall mounting with some sound deadening material.
__________________
Rolf
Donate
Old 19-06-2007   #4
Oldgeezer
johnsattuk's Avatar
My System: Topfield 5800 Echostar3000,DB7000, Relook 400S, Humax HDC2000, 55cm Fibo Gregorian dish with waveguide and Motek 2100 mod, 90cm Fibo Gregorian dish, 120cm Fibo Gregorian dish on a 1224 motor with waveguide
Originally Posted by dasteelman View Post
My question is this....is there anyway I can reduce/absorb the sound of the motor? I was thinking of even wrapping sponge around it??
Most of us have this problem to some extent.
Whilst some motors are undoubtably quieter than others, they are all coupled to a large resonant loudspeaker type cone, damping material on the back of the cone can usually reduce the more annoying high freq. content. I have experimented a bit with a variety of things and have ended up using the type of stuff used on car body panels. Can't recall who, but at least one member got good results with expanding foam on the back.
__________________
Oldgeezer
johnsattuk is offline   Reply With Quote
Old 19-06-2007   #5
lifes not a practice run
4dbennett's Avatar
My System: technomate diseq 1500ci+ ibm thinkpad
You could invite the nieghbour down to watch some porn, may stop the complaints??? LOL,
only joking, I bought some expanding foam and coated the body of the motor, works fine !!
deep joy dave
4dbennett is offline   Reply With Quote
Old 19-06-2007   #6
dasteelman's Avatar
thanks guys...
at work we have like a machine that produces expandable foam for when we pack things.
4dbennet .... is the foam you bought just like that DIY stuff in a gun or a spray like this:-
h**p://w*w.oldhouseweb.com/stories/Detailed/13174.shtml
Old 19-06-2007   #7
I put my sleeping pillow as temporary at the back of the dish, it reduced the noise much but not enough.
I have huge problems with this also as i use my motor during the late night early morning hours.
As my neighbor has their bedroom above my dish and they have the balcony door open during night you can imagine how much it annoys them.
Likvid is offline   Reply With Quote
Old 19-06-2007   #8
But you live in a house so you can have whatever you like.
Old 19-06-2007   #9
4dbennett's Avatar
thanks guys...
In a spray m8, wear some gloves and mould it as you spray, spray very gently, cut off any excess when dry, best of luck,
deep joy
dave
The Following User Says Thank You to 4dbennett For This Useful Post:
dasteelman (19-06-2007)
Old 20-06-2007   #10
My System: channel master 1.2m dish technomate 6900,,and invacom 0.3 quad lnb satlook micro
ive got a superjack arm via a vbox and i fitted a large resistor in line with the motor makes it slower but also reduces noise on my 1.2m dish
iwol is offline   Reply With Quote
[IMG] code is Off
Forum Jump
