dreambox 500s wireless? | |
| Regular Member Join Date: 29-02-2004 Location: Tyne and Wear
My System: 85cm transparent dish 0.2db lnb titanium wf100 cable dreambox500s technomate 9100 linux Eaglebox UK nds card |
anyone know the best way to connect my 500s to wireless router#? | ||
| Regular Member Join Date: 13-06-2005 Location: Teesside (North East England)
My System: Dreambox 500-s, 80cm Dish, 1.2 Compatible Motor | im also after knowing this, my router is downstairs and my laptop and dreambox is upstairs in my bedroom. I hear the best thing to do is cable it but i obviously cant so what ill have to somehow do is connect the dreambox into my eithernet port on my laptop and then transfer files/connect to the internet that way through my wireless network card. the downside of course is if the connection cuts out at anytime while sending data to the dreambox i hear its a hard job putting everything right again if you use wireless. Quite how you actually do set it up like i want and how i persume you want im not sure, hopefully somebody can explain hehe | ||
| Super Moderator Join Date: 08-03-2005 Location: J6 M5
Blog Entries: 1 My System: DM7020S ~ DM500s ~ sg2100 ~ Gemini ![]() If he were not a wizard, from head down to the root, you would have got to worry-your DB only boots | Try a search on "Etherrnet bridge" I can't remember if it works with a DM500 but there are some posts that will help. | ||
| | #5 | ||
| Specialist Contributor Join Date: 29-08-2004 Location: dublin,ireland
My System: dreambox 500s gibertini 85cm dish superjack 120 motor........ linksys access point connected to dreambox...Humax HDCI 2000...S*Y sub + 60cm dish...sony rdr-hx 725 160gb HDD recorder | Hi dasteelman.. I use a Lynksys G wireless access point..my wireless router is in the front of the house and my dreambox and access point are at the rear...the access point is sitting under the dreambox it picks up the signal and transfers it thru a cat5 cable where I can update images/keys etc..It can be a bit finiky to set up but I got all the help I needed here in the idiots guide..plus a lot of help from super mod john graydon who just happens to be local to me so I could contact him personally. hope this helps..good luck gandalf | ||
| The Following User Says Thank You to gandalfthegrey For This Useful Post: | dasteelman (15-06-2007) |
| | #6 | ||
My System: Dreambox 500-s, 80cm Dish, 1.2 Compatible Motor | so to connect you the router you have to go from dreambox to router, you cannot go via computer (only to update files). so if i want to do 1 of these services where i have to be connected to internet all the time i will have to cable it from box to access point, i cannot connect to my laptop and go through its wireless connection. ok i think i get it. I buy a wireless access point and connect my dreambox to that in my bedroom or something, instead of taking my dreambox to the router Last edited by Sharkadder; 16-06-2007 at 12:16 AM. | ||
| | #7 | ||
| Regular Member Join Date: 19-08-2005 Location: Torbay, Devon
My System: Mondeal 7500 + Dragon cam. 1M moveable dish DB500s | I have a wireless wanadoo connection in my house. My laptop is wireless but the 500s is hardwired to router. I just put the ip address of the 500 into my laptop, and can load images key bundles etc. Only problem is new laptops do not have aserial port to use dream up. Tim. | ||
| | #8 | ||
| Specialist Contributor Join Date: 06-08-2004 Location: Down South
My System: Dreambox 7020si, Dreambox 7000s,DS v3.6,PB Enigma 2.0.1, Nabilo v0.8,SIF Team v1.8.9,pli Helenite,EDG v4.0 Netgear adsl router, 98cm Funkee on Diseqc motor, Maintaining Hummy 5400 for the old man! | I use a bridge on my TM9100 and used it on my DB a few years back with no problem, I used the guide in the sticky's here and even bought the bridge described in the guide. Without questioning Dig as I have know he is very knowledgeable but the bridge uses the same 128bit security as my router so I assume this is as secure as my router. | ||
| | #9 | ||
| Regular Member Join Date: 14-05-2007 Location: Blue Planet
My System: Technomate 5200USB Echolink, 80cm dish and a motor | I put my old pc connected via the cross cable to the dreambox and the pc is using a usb wireless connection to the route. I have shared the internet connection on the pc and put the ip address on the dreambox like 192.168.0.4 and is working fine. | ||
| | #10 | ||
| Thank Me not my Boobs Join Date: 19-12-2002 Location: 47°N/8°E/490m
My System: Sky+ v2 (120Gb); DM7020Si*motorised; PC/S2-3200 | Wireless ethernet bridges will support encryption - let's not say they're "not secure" - you just have to set it up correctly. You need a good connection should you want to record or stream effectively across this wireless connection - G or pre-N/Mimo will help (as well as few walls, etc). | ||
| | #11 | ||
| Prince of Birthdays Join Date: 28-09-2005 Location: Sweden
My System: Dream7020 and lots of junk all over the place | Sorry about the security guys, I am somewhat overdoing this ![]() Let us say that 128 bits is good then (for heavens sake) change the password to the box ![]() U can´t be too secure today | ||
| | #12 | ||
| Member Join Date: 13-04-2005 Location: Birmingham UK
My System: Technomate 1500CI+,Gibertini motorised dish,Titanium 0.2db LNB | I've just ordered a Belkin wireless gaming adapter (Bridge). It hooks into the ethernet port, and is the same piece of kit you'd use for a slingbox. Costs £39 delivered. Will let you know how I get on. (Also have a Dreambox 500s on the way) | ||
| | #13 | ||
My System: Dreambox 500-s, 80cm Dish, 1.2 Compatible Motor | you best let us know how you get on.......because i have just ordered the same thing lol. waiting for it to arrive in the post now that i have some cash to spend this time of year. I hear these can sometimes only work with certain ISP's. I've also orfdered one of these wireless digisenders so i can transmit into another room, i'm not sure if i can have 2 scart connections into it with it being a digital one but i'll see when it arrives in next few days. but i will also let people know how i get on. ![]() | ||
| | #14 | ||
| Member Join Date: 30-03-2006 Location: Portsmouth
My System: DM500s, 80cm Dish, 6degree MonoBlock 13e/19.2e. Nabilo v0.8 | Has anyone tried these with their DreamBox? _h**p://www.cyberselect.co.uk/product/1275 Ethernet over the mains. My kit is on order and this is how mine will conect to my netgear. (I'm desperate for it to arrive) 1st post, so hello ![]() | ||
| | #15 | ||
My System: Technomate 1500CI+,Gibertini motorised dish,Titanium 0.2db LNB | Well, the Belkin gaming adapter seems to be working ok. Once in it's virtually invisible (other than to the router and DM of course) and you can't log into it directly. It seems pretty secure to me. | ||
| | #17 | ||
My System: Dreambox 500-s, 80cm Dish, 1.2 Compatible Motor | i also use belkin gaming adapter and you can log into it directly, belkin have a web interface port, i forget what it is but you can change numerous things on the bridge such as ip address and add a WEP key if needed for it to work. works a treat but theres meant to be some 64kbit ones available which work better than the belkins.
__________________ | ||
| | #18 | ||
| Member Join Date: 21-03-2007 Location: uk
My System: DM 500 | Hi, I would like to connect my dreambox 500s to pc and need some help. I have wireless system (D-Link, Air plus G2.4GHz wireless access point with D-Link USB stick). Many thanks. Vlb | ||
| | #19 | ||
My System: Dreambox 500-s, 80cm Dish, 1.2 Compatible Motor | sorry.....ethernet only dude, i have the same model, no usb interface. what you need is to buy a wireless ethernet bridge or wireless gaming adapter or something with ethernet interface. USB stick is no good, you connect box to pc via CAT 5e/6 LAN ethernet cable but even so your better off connecting the box directly to your router/modem using ethernet cable
| | #20 | |||
My System: DM500s, 80cm Dish, 6degree MonoBlock 13e/19.2e. Nabilo v0.8 | They are not fast enough for VLC front end ![]() By running a long ethernet cable across the floor VLC FE worked fine But would not work through powerline adapters Apparently there are some 200mb models available Or I could re-wire my house..... | |||
| | #21 | ||
My System: DM500s, 80cm Dish, 6degree MonoBlock 13e/19.2e. Nabilo v0.8 | Further update on POWERLINE adapters ![]() And don't plug them into a 4 gang ![]() Plugged directly into wall outlet they are working a treat VLC and recording to mounted drive ![]() One slight issue i put a dhcp reservation in my netgear so i could give it a hostname Via MAC reservation (So it always gets the same address) Well it doesn't and just keeps getting random one's So its on a static IP currently | ||
