Cifs mount zone alarm probs
Thread Tools Display Modes
Old 22-08-2007   #1
rogue_element's Avatar
Hi there
After a long time of doing nothing more than updating D+ k*ys on my dm5620 I thought it time to fiddle (with the dreambox) I have been trying to set up a cifs mount so I can record on my pc's HDD. I try'd loads of diff settings on the dreambox that all ended in mount failed. As a last straw I try'd turning off zonealarm firewall and the fecker worked does any one know how to get zonealarm to trust the dreambox I cant see any setting in zonealarm to do it, as I cant leave it off.
Thanks in advance
R_E
__________________
Some say hard work never killed anybody, i say why take the risk?
My System
I have a Dreambox 5620 (soon to be home to a Digital Alb card) running Gemini and Newcamd, 80cm dish on 30w(crap i know fitting h to h soon),pc linked via crossover, viewd on a 44" Dlp rear-pro tv
rogue_element is offline   Reply With Quote
Old 22-08-2007   #2
mhku's Avatar
My System: DM7020S ~ DM500s ~ sg2100 ~ Gemini
If he were not a wizard, from head down to the root, you would have got to worry-your DB only boots
I gave up trying and installed Kerio.
__________________
You don't stop playing because you get old, you get old because you stop playing. Regras
Before posting in the Dreambox section please ensure you've read The Guide
Information is for educational purposes only
mhku is offline   Reply With Quote
Old 22-08-2007   #3
Kerio???? who he??
__________________
My System
Old 23-08-2007   #4
mhku's Avatar
_http://www.google.co.uk/search?hl=en&q=kerio+firewall&btnG=Google+Search&m eta=
__________________
Old 23-08-2007   #5
Oh I see
I thought it was something to do with Gemini, can u tell me if u got this recording thing working ok with the new firewall, I have been using ngrab it works but goes out of sync and drops frames making the results crap.
Thanks for all the advice
__________________
My System
Old 23-08-2007   #6
Prince of Birthdays
dig deep's Avatar
My System: Dream7020 and lots of junk all over the place
U can tell zone to allow connections to the box if U use a static IP addy
dig deep is offline   Reply With Quote
Old 23-08-2007   #7
mhku's Avatar
Yes, recording with CIFS works fine using Kerio as my PC firewall.
__________________
Forum Jump
