Slow cam initialization
Old 10-09-2007   #1
lucasss's Avatar
My System: triax 1.1 / dream 500 / MTI 0.3
Unhappy Slow cam initialization
Hello all
If you could help it would be very appreciated.I had installed gemini 3.6 and everything was ok.
Now i instaled gemini 4.0 and copied all my files which i needed to this version by FTP-ing them and i gave them the correct attributes.
Does anyone know why now the cam is initializing very very late if i restart it?
So besides that the files are 100% the same as in the older version ,now the time for the cam to be initialized is sixth times as more.
Thank you.
lucasss is offline   Reply With Quote
Old 10-09-2007   #2
Archived Member
Are you sure it it is Gemini 4.0 ?
The latest I know of is Gemini 3.6
HB13DISH is offline   Reply With Quote
Old 11-09-2007   #3
lucasss's Avatar
Yes i am sure.
Are you?
Old 11-09-2007   #4
Archived Member
Thanks for the confirmation.
I will flash it this weekend and see if I get the same problem.
Old 12-09-2007   #5
Archived Member
Installed the Gemini 4.0 and it was worth it. There is a better addon menus and files.
No problem with the CAM initialization. Maybe because I started everything from scratch, scanned and made a new channel list.
Old 12-09-2007   #6
delectable's Avatar
My System: Sky +, Technomate 1500ciSuper, Dreambox 7025, 85 cm Transparent dish, titanium 0.2lnb, Tecnomate 2200 motor
same
Had similar problem last night. Couldn't decode anything after restarts or reboots inc from my local card. Left over night and fine in the morning but a pain.
Not sure which ver of Gemini, but will check.
Started from sratch last weekend too!!!
delectable is offline   Reply With Quote
cam, initialization, slow
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. Uptime monitoring by PageUtils.com
