cccam sharing
Dreambox information exchange on the best dreambox software images and help with all other operational problems with your Dreambox. The ultimate Dreambox satellite TV support forum.
Old 27-12-2007   #1
My System: dm7000s+dm500s
cccam sharing
Hallo can somone show me how to share with cccam from dm 7000 to use with dm 500
i dont know the config file how to
ps need national geo channel what card must i buy
ritzik
ritzik is offline   Reply With Quote
Old 27-12-2007   #2
Site administrator
Analoguesat's Avatar
Post split from the topic you had posted in as it wasnt relevant to that discussion
Analogue forever!
Analoguesat is online now   Reply With Quote
Old 27-12-2007   #3
Manic Midlander Moderator
nanochickin's Avatar
My System: Dreambox 7020si, Technomate TM600, Technomate TM9100 Fracarro Penta 85 Dish, Televes 0.6dB Quad lnb, TM SG2200 motor. 60cm Channel Master BSB dish on 28e, Mti Blueline 0.2db Twin Lnb. Rover ST-4 Meter Cyfra+ Subscription
ritzik
Which National Geographic are you talking about mate. Its on virtually every Satellite up there
If you have a look in Var/Etc on either 500 or 7020 you will find a file called cccam.cfg, you might be able to figure it out from there
I don't use CCcam so i couldn't tell you how to set it up but it should get you on your way if you look in the file.
Nano
Sanity is nothing more than an excuse to be boring
<<<<<<<<****** Dreambox DM7020 Si , S.I.F 1.9.3d ******>>>>>>>>>
<<<<<<<<******** Technomate TM9100, EDG 4.4 ******** >>>>>>>>
<<<<<<<<<<******* Technomate TM600, UR 23 *******>>>>>>>>>
nanochickin is online now   Reply With Quote
Old 27-12-2007   #4
My System: WinXPProSP2
I hope this will help
CCcam and cardsharing
To configurate and connect the CCcam, you need to go to the ETC folder and edit the
CCcam.cfg file.The CCcam config file itself is a little help file. Indeed, you will find many text
lines starting with #. These lines provide help to set the CCcam, and there is no need to
delete them as they are ignored by CCcam. Therefore, they can also be used to add any note
or comment.
The configuration lines can be written in any order. There is no standard order to respect.
Indeed, when started, CCcam reads the first character of each line and executes the request.
Let’s look at each line syntax now.
F: Friends
F: user1 pass1 1
C: Connect
C: server.dyndns.org 12000 user1 pass1
The C line (where C stands for connect) enables the CCcam to connect to another server
The URL or IP after C: is necessary to identify the server in the sharing network. 12000 is the
port used by the server to communicate and user1 pass1 identify the user
Note: each user is accepted only once by the server
How to connect a client to a server:
The F line launches the server, whilst the C line launches the client, and this is all you need.
Should the client wish to share its subscription cards with the server, then you need to add a
C line at the server, and an F line at the client.
Log Diagnostic
Should you wish to check whether the connections are working properly, then use the CCcam
–dv Telnet command. This option will give you the possibility to check the log and make sure
all is ok.It may be useful for beginners to do it with Telnet, and, once experienced, it may also
be done using the the automatic script found in the blue panel.
Cam log removed - admin
PetSat is offline   Reply With Quote
Old 17-05-2009   #5
My System: humax 5400
can someone help me I want to conect my two dreamboxes with the same cline.
i do not know how to do it
can someone help me please
ghalqa is offline   Reply With Quote
Old 17-05-2009   #6
T_G
The Consumate Dreamer
T_G's Avatar
Location: Somewhere where the Sauer is Kraut and the Wurst is Brat
My System: I bet on red. If I lose, I double the bet on red again. I continue with this until I lost everything.
Muhuhuhahahahahaaaaarrrgggh
There are quite a few threads about card sharing problems. There is also a tutorial about card sharing in the guide section. If you have a specific question that is not covered yet, then you need to tell us. Also, what have you been doing so far, what happened, etc etc. If you want help, you got to help us help you
T_G
I only believe stuff that comes straight from Mr. Horses mouth!
T_G is offline   Reply With Quote
Old 18-05-2009   #7
Dreambox Gimp & Coder
B16MCC's Avatar
My System: 2 Dreamboxes ------ DM 8000 HD PVR ------- ---------- DM 800 HD ---------- -------- Motek SG2100 -------- ---- Triax 80cm Dual LNB ----- -- Fixed Dish 28e Quad LNB -- ---------- Sky HD Full ---------- ------- 24" Apple iMAC --------
Creator of the CCCCC - only a true wizard could come up with such a name!!
Ok guys, a few pointers to get started.
1. Read my guide 5 times.
2. Don't be scared by the CCcam.cfg file , its contains loads of info you don't need
3. If you want to share 1 box to another , your config files are just 1 or 2 lines thats all.
There are 10 types of people in the world. Those who understand binary and those that don't.
Check Out My Blog :- Dreambox Utils For Windows
Best Regards, Your Friendly Dreambox Gimp.
B16MCC
B16MCC is offline   Reply With Quote
Old 25-09-2009   #8
Real name: George
My System: dreambox 500/sky HD 1mtr motorized dish
telnet cccam
hi sorry to be a pain
i have followed most of the threads on sharing my card with a friend, for days now and was hoping to crack it myself
i thought i had done all the relvant files and so on, my card is working ok
in my tm500 with ur 13082009
using cccam2102+newcs1.67.
when i telnet and CCcam-dv i get -sh: CCcam-dv not found !!!
am i missing a file in the scripts ! what am i doing wrong
i have my f lines and clients clines in both boxes.
thanks for any help:
dale094 is offline   Reply With Quote
Old 25-09-2009   #9
compufunk's Avatar
My System: DM 600-S, AB IPBox 9000HD, Moteck SG2100, Fracarro Penta 85 dish, + some puters
First of all you need to use a space between the command and the switch.
use
CCcam -dv
instead of
CCcam-dv
You may also need to use the full version name i.e. to start CCcam from the command line I would need to type CCcam_2.1.1
To find it on your system, run the following command.
 find / | grep CCcam
Its probably in /usr/bin/ or /var/bin/, but your file structure may differ from that of the dreambox
compufunk is offline   Reply With Quote
Old 25-09-2009   #10
Real name: George
yes i have tried CCcam -dv with space still get same response
i have reloaded nabilosat image for the tm 500 new and still get the same when i telnet CCcam -dv now usin CCcam 2.11 +newcs 167 white card works ok
i must be misssing something ?
Old 25-09-2009   #11
compufunk's Avatar
Yes, but are you even sure that the file binary file is called CCcam?
As I already mentioned, find the file by running ....
find / | grep CCcam
Old 25-09-2009   #12
shumifan50's Avatar
My System: 2xDM7025(DVB-S tuner), DM600SPVR, DM800S, TM9100, Triax 90cm with MultiBracket 4 sats.
Better to run "find / -name CCcam*"
shumifan50 is online now   Reply With Quote
Old 25-09-2009   #13
compufunk's Avatar
Not really. That will only find files called 'CCcam'. It wont for example find a file called CCcam_2.1.1 or CCcam_2.1.0 or whatever. Which is how they will be named by default.
Old 25-09-2009   #14
shumifan50's Avatar
Note the * at the end of CCcam, that means it will find CCcam......
Old 25-09-2009   #15
compufunk's Avatar
Ooops, Missed that. Its much of a muchness in any case. The output is the same.
Old 25-09-2009   #16
Blimey, have you seen when the first post was made, back in 2007 when i was using gBox
Old 26-09-2009   #17
Real name: George
need help
hi again
have tried telnet. find -cccam*
result !!
busybox v1.2.1 (2006.10.11-21:54+0000) multi-call binary
usage: find [path...] [expression]
i cant get my head round this
Old 26-09-2009   #18
shumifan50's Avatar
This is not windows - file names are case sensitive to start with. Further spaces cannot be imitted. So type the following EXACTLY is it is
find / -name CCcam*
Dont leave spaces out or insert any spaces and CAPS ARE REQUIRED
Old 26-09-2009   #19
compufunk's Avatar
You can just copy the commands from this webpage and paste them into your telnet sessions console.
Old 26-09-2009   #20
Real name: George
ok so that command worked .
shows me directories /var/bin etc.
shows me that i have CCcam etc.
so where do we go from here !!
i know i have CCcam + newcs because their working on my old **** card on ***
i just need some easy steps to set up a share with my m8
sorry guys if i sound a bit thicko, i can assure you not .
got my port forward working , dyndns account setup and updater
CCam info pages are up on browser
where am i going wrong
thanks guys.
Old 26-09-2009   #21
Site administrator
Please DO NOT post full cam logs on the forum - its something we are discouraging as it could leave us open to legal action for promoting illegal decryption of pay tv.
Analogue forever!
Old 26-09-2009   #22
Real name: George
sorry for breaking the rules it will not happen again!!
Old 26-09-2009   #23
Site administrator
No problem - its something we have decided recently that we need to crack down on as several threads a day were appearing with loads of hex codes and lord knows what in them.........
Analogue forever!
Old 26-09-2009   #24
Real name: George
once again apologies i fully understand it was a fit of desperation so to speak.
i agree fully with the rules and will not be so explicit with my questions in future
thanks anyway.
cccam, sharing
