Flash image to DM600 - no serial port | |
| | #26 | |||
| Specialist Contributor Join Date: 27-04-2004 Location: NW England
My System: Dreambox 500, Dreambox 600PVR, Dreambox 7025+, Dreambox 7000, 1m dish on a Moteck SG2100 | Like said you dont need to know what the TV screen says. After flashing you will know if it worked, power it up again and see if you get the green light come on after it was booted, might take a couple of minutes to boot. | |||
| | #27 | ||
| Regular Member Join Date: 10-11-2004 Location: Cheshire
My System: DM600PVR (Poorly) TF6000 (Poorly) SkyHD | Well, rather than spend three days looking for my null modem cable I ordered a new one. I'll do the reflash when it turns up... ![]() | ||
| | #28 | |||
| The Consumate Dreamer Join Date: 01-01-2000 Location: Somewhere where the Sauer is Kraut and the Wurst is Brat
My System: I bet on red. If I lose, I double the bet on red again. I continue with this until I lost everything. ![]() Muhuhuhahahahahaaaaarrrgggh | ![]()
__________________ I only believe stuff that comes straight from Mr. Horses mouthHelp build Satellites City! Help build the Satellites MiniCity - no downloads, no money involved, just a daily click onto the site. More details here: http://www.satellites.co.uk/satellite/717922-post1.html | |||
| | #30 | ||
My System: DM600PVR (Poorly) TF6000 (Poorly) SkyHD | Took a long time but I finally did it. Used the null modem cable only because the IP range at work is different to that at home and it would have taken me as long to change the IP on the DM600 as it did to flash over null modem. In the end it took 25 minutes to re-flash the latest Gemini (4.4), so we'll see if it works when we get it home. | ||
| | #31 | ||
| Member Join Date: 24-06-2008 Location: s.wales
My System: dreambox,technomate motorised dish | dm600 does take about 25-30min with null cable, also try different versions of dream up i found latest version would'nt work. you might find some images not stable, i prefer older versions (tried and tested) | ||
| | #33 | ||
| DB Magician Join Date: 19-07-2003
![]() Merlin of the Idiot Guide | A simple way to install a new image (or a number of images) is to use multiboot with the Barry Allen plugin. I have posted a how-to here :- h**p://www.satellites.co.uk/satellite/dreambox-general/128733-how-barry-allen-dm600pvr-5-minutes.html Regards, pcd. | ||
