Originally Posted by mhku Perhpas you're better of asking in the ProgDVB section as your question has nothing to do with a Dreambox? Do you want me to move this thread? |
The reason using picture from ProgDVB is to make it clear, that the channel using multi ecm, I think it is better to using a picture than log from dreambox, logs from dm is as below:
18:53:17.571 CCcam: found viaccess caid: 0x500 ecmpid: 0x206 id: 0x21e00
18:53:17.572 CCcam: found viaccess caid: 0x500 ecmpid:
0x606 id: 0x23900
18:53:17.573 CCcam: found viaccess caid: 0x500 ecmpid: 0xbc2 id: 0x31d00
18:53:17.580 CCcam: found viaccess caid: 0x500 ecmpid: 0x9d4 id: 0x21e00
0xa38 id: 0x23900
18:53:17.581 CCcam: found viaccess caid: 0x500 ecmpid: 0xbc3 id: 0x31d00
18:53:17.582 CCcam: cam[0] set PMT for sid=e
18:53:17.584 CCcam: start EMM
18:53:17.621 CCcam: EMM demux 1 set
18:53:17.622 CCcam: EMM: not interested in 0500:FFF840
18:53:17.689 CCcam: viaccess emu can't decode ecm (key:0 ident:21e00)
18:53:17.689 CCcam: remote ecm -> somedomain.com:12345 0x500(0x21e00)
18:53:17.715 CCcam: remote ecm <- somedomain.com:12345 error
18:53:17.716 CCcam: cam[0] ecm odd nok caid:0x500 id:0x21e00 pid:0x206 D-
Skynet (138E)
18:53:17.754 CCcam: viaccess emu can't decode ecm (key:0 ident:23900)
18:53:17.780 CCcam: remote ecm -> somedomain.com:12345 0x500(0x23900)
18:53:17.986 CCcam: remote ecm <- somedomain.com:12345 ok
18:53:17.986 CCcam: cam[0] ecm odd ok caid:0x500 id:0x23900 pid:
0x606 D-
Skynet (138E)
PID
0xa38 is not handled by CCcam, so only I can only get video
