TuxVisionR improved for DM5620, DM600pvr .. | |
| DB Magician Join Date: 19-07-2003
![]() Merlin of the Idiot Guide |
For better streaming from DM5620, DM600pvr, DM500 and other boxes with Enigma1 image . Hi Friends, TuxvisionR is a development from the original Tuxvision to be used with enigma1 images. It was published in 2006 and proved to be a popular Windows tool for watching and recording Dreambox tv using lan. The new version TuxVision_2.01 has been developed with a dm600pvr but should also be useful for other boxes with enigma1 images. This version has more audio/video bitrate range (means works with more channels). Also possible now to select a channel and view the epg and to check the dreambox connection status. Right-click on the video for full-screen view menu. Instructions :- (1) Install program TRex from here :- h**p://www.dbox2.info/download.php?viewpage=2&catid=5&subcat= (2) Next unzip and save the attached folder TuxvisionR_2.01 in, for example, c:\ (3) On pc at start>run>cmd write : cd (path to folder TuxvisionR_2.01) regsvr32.exe DBOXIISource.ax (a 'succeeded' message should appear) (4) With pc connected to db with lan, go to the folder and start program tuxvisionR.exe. Select 'Preview' to watch the channel currently running on tv. Or select another channel. Note:- With Vista the filter (.ax) install requires admin previlege. Only channels in bouquets can be selected. If you have installed an earlier Tuxvision or TuxvisionR, first uninstall the filter DBOXIISource.ax. For this, please give this command first (after cd to folder with the earlier DBOXIISource.ax) : regsvr32.exe /u DBOXIISource.ax (a 'succeeded' message should appear) To see bouquets and epg, remove HTTP Authentification requirement from the expert setup list. Please report any problems. Regards, pcd. | ||
| Member Join Date: 29-11-2006 Location: Co Down
My System: Triax TD88 with Moteck 2100A motor. Dreambox 500S. | Thanks for this, look forward to trying it out. I've been using v1.01 to watch 4:2:2 footy feeds, it's the only thing I've found that gives me a watchable stream. Very useful bit of software. | ||
My System: Triax TD88 with Moteck 2100A motor. Dreambox 500S. | Just to give some feedback on this, I've tried version 2.01 on a couple of different PCs now and have yet to get it working, always gives a blank channel list, so I have resorted to using the old version. | ||
| Member Join Date: 04-09-2008 Location: Asia
My System: DreamBox DM500-S | Windows error msg - "LoadLibrary("dboxiisource.ax") failed - This application has failed to start because the application configuration is incorrect. Reinstalling the application may fix the problem.", when executing regsvr32 on windows XP under adminstrator How do I reinstal regsvr32.exe ? | ||
| | #5 | ||
| Super Moderator Join Date: 08-03-2005 Location: J6 M5
Blog Entries: 1 My System: DM7020S ~ DM500s ~ sg2100 ~ Gemini ![]() If he were not a wizard, from head down to the root, you would have got to worry-your DB only boots | It's not regserver that is at fault - it is component that you're trying to register - dboxiisource.ax ? | ||
| The Following User Says Thank You to mhku For This Useful Post: | Myhd (21-09-2008) |
| | #6 | ||
My System: DreamBox DM500-S | reinstalling "regsvr32.exe Dboxiisource.ax" DboxiiSource.ax from TuxvisionR v2.01 and v1.01, register same windows message. Any other suggestion? Problem solved. works on another PC Last edited by Myhd; 21-09-2008 at 03:48 AM Reason: Solved | ||
