Key updater for the 7025 | |
| Super Moderator Join Date: 08-03-2005 Location: J6 M5
Blog Entries: 1 My System: DM7020S ~ DM500s ~ sg2100 ~ Gemini ![]() If he were not a wizard, from head down to the root, you would have got to worry-your DB only boots | The normal options are: 1. manually upload using FTP 2. install a plugin e.g. hacksat key downloader V8 I'm not sure of any compatibility issues for a 7025 as I don't have one. | ||
