How to get Premiere EPG | |
| Super Moderator Join Date: 08-03-2005 Location: J6 M5
Blog Entries: 1 My System: DM7020S ~ DM500s ~ sg2100 ~ Gemini ![]() If he were not a wizard, from head down to the root, you would have got to worry-your DB only boots |
I'm sure everyone else knew how to do this but I only found it by accident. To view Premiere EPG while watching Premiere (1-4 and Direkt), press the red button on your remote and you'll see a list of the films for next 4 days. Then press the green button to set the timer recording. Pressing the green button when you first go to Premiere Direkt will allow you to select the subservices e.g. channels 1 - 5. I'm sure it's probably in the manual and the I.G. but just in case ...
__________________ Last edited by mhku; 02-04-2008 at 09:24 PM | ||
