Recorded Movies from DM600 to DM500+
Thread Tools Display Modes
Old 31-03-2008   #1
Yannis's Avatar
My System: Hotbird (13E) - Dreambox DM-600PVR, DM-500+, WinXP.
Hello experts!
I'm using a DM600PVR to record movies in his internal Hard Drive. The movies stored in the DM600PVR, reside in /media/hdd/movie/.
I can see these movies (through 'File Mode') with no problem.
I have a 2nd DremBox (DM500+) in the same LAN. The question is:
How can I see these movies from DM500+ ?
This might be obvious to you, but to me as a newbie, looks like a mountain to climb on.
thanks
Yannis
PS I'm using Gemini 4.20 with CCcam 2.0.5
Yannis is offline   Reply With Quote
Old 01-04-2008   #2
mhku's Avatar
My System: DM7020S ~ DM500s ~ sg2100 ~ Gemini
If he were not a wizard, from head down to the root, you would have got to worry-your DB only boots
I've not done this but I would suggest setting up a mount of Dreambox 2 on Dreambox 1, in the same way that a PC hard drive is mounted.
Details are in the Guide.
__________________
You don't stop playing because you get old, you get old because you stop playing. Regras
Before posting in the Dreambox section please ensure you've read The Guide
Information is for educational purposes only
mhku is offline   Reply With Quote
Old 01-04-2008   #3
Yannis's Avatar
Thanks for replying.
What do you think i have to use as file system for this mount? (NFS or CIFS)
Thanks again
Yannis
Old 01-04-2008   #4
mhku's Avatar
If both Dreamboxes use the same image then I'd try CIFS.
__________________
Old 01-04-2008   #5
Yannis's Avatar
Thanks, I'll let you know!
Forum Jump
