13-04-2008
#11 |
| Specialist Contributor
Join Date: 13-06-2005 Location: Teesside (North East England)
My System: Dreambox 8000 HD PVR, 80cm Dish, 1.2 Compatible Motor, Quad LNB, Porty TV, Yamaha RX-V765 Amplifier, Tannoy Mercury FC Centre Speaker, 2 x Tannoy F1 Custom Speakers, 2 x Tannoy FR Custom Speakers, EPOS ELS Sub Woofer | same happens on the dreambox 500-s, the answer is use stream channels not dev-stream channels. If you can convert the data channels to tv on your box then the channel's will display.
That is what you do on the DB, just simply convert the stream channels to tv from data, as for dev-stream i have never got them working. Although the t4 ones do in multiscreen |
