Originally Posted by B16MCC A small problem here mate. I'm on a DM7025 I don't get the same plugin list as other boxes. The bitrate viewer is not on my list. If you know its available for 7025, then I'm more than happy to get it installed and help the project. I checked IHAD but its not there.
I've just realised there's similar util already in blue panel, system info, stream traffic. This does show me a video and audio bit rate, however the video moves a lot. Am I right in thinking your plugin gives you an average value. The value I see can move over 800kbit in a couple of seconds. Its almost impossible to record it.
Any suggestions ?
Regards
MCC |
There is probably a good reason why it is not on the list.
I don't think that it would be a good idea to install a plugin that might not be suitable for your box.
Thanks for your offer to help.
I didn't like the stream traffic monitor in the past. This is why I used the plugin instead. Gives four values as shown in post #1
