Sky Sports Active (Match Choice)
Dreambox information exchange on the best dreambox software images and help with all other operational problems with your Dreambox. The ultimate Dreambox satellite TV support forum.
Old 27-04-2008   #1
Dreambox Gimp & Coder
B16MCC's Avatar
My System: 2 Dreamboxes ------ DM 8000 HD PVR ------- ---------- DM 800 HD ---------- -------- Motek SG2100 -------- ---- Triax 80cm Dual LNB ----- -- Fixed Dish 28e Quad LNB -- ---------- Sky HD Full ---------- ------- 24" Apple iMAC --------
Creator of the CCCCC - only a true wizard could come up with such a name!!
Wink Sky Sports Active (Match Choice)
Hi peeps, I've been meaing to have a go at this for a while, and so here it is.
I wanted to setup the Sly Sports Match Choice channels as available from the red button. After a little tinkering I've got it all up and running. When scanning the transponders the first thing I noticed was the SID's in question came in as Data type. So using dreambox edit I've changed the service type and corrected the VPID and APID info. So far I've got the menu screen and 7 match choice channels. I've attached the bouquet file from dreambox edit for others to check out. I"m not sure if this file alone is enough info for others to add the bouquet, if not then please let me know and I'll supply what ever else is needed. Simply remove the .txt from the file name. Enjoy the footy !
File Type: txt userbouquet.dbe0a.tv.txt (543 Bytes, 62 views)
B16MCC is online now   Reply With Quote
The Following User Says Thank You to B16MCC For This Useful Post:
salv90 (27-04-2008)
Old 27-04-2008   #2
My System: Dreambox 7020
Thanks man, this is exactly what i have been after for a while.
The thing is I got no idea what u mean in ways of installing it.
I am currently using the captains settings, which I have painstakingly personalised, how do I put your list in there or wherever they go.
BTW will this also work for their champs league nights.
salv90 is offline   Reply With Quote
Old 28-04-2008   #3
T_G
The Consumate Dreamer
T_G's Avatar
Location: Somewhere where the Sauer is Kraut and the Wurst is Brat
My System: I bet on red. If I lose, I double the bet on red again. I continue with this until I lost everything.
Muhuhuhahahahahaaaaarrrgggh
Nice work B16. I haven't put it in yet, but I will. What happens if you rescan this satellite? When you save the doctored stations, do you untick the automatic update option for these channels?
@ Salv: What you do is use the dreamboxedit program (there are seveal threads here in the dreambox section dealing with it, and also I think in the idiot guide. Basically you use the tools, compare loaded services with other services on disc for instance, and then you can tick which ever station you want, or all of them.
T_G
I only believe stuff that comes straight from Mr. Horses mouth!
T_G is offline   Reply With Quote
Old 28-04-2008   #4
B16MCC's Avatar
Talking Dreambox Edit
Yes thats right mate. I use the 'force use pids' check box, so any scans will keep the info I changed it to.
It looks like when match choice is not on you'll get some strange results, so I'm waiting to see what happens next time.
Old 28-04-2008   #5
My System: Dreambox 8000 HD PVR, 80cm Dish, 1.2 Compatible Motor, Quad LNB, Porty TV, Yamaha RX-V765 Amplifier, Tannoy Mercury FC Centre Speaker, 2 x Tannoy F1 Custom Speakers, 2 x Tannoy FR Custom Speakers, EPOS ELS Sub Woofer
maybe a proper tutorial on this would be ideal, i tried uploading the bounqet last night and modifed my bounqets tv file to include it. I found it but it didn't currently carry a signal.
If we keep getting interactive channel like this, somebody could easilly add an interactive plugin with it all in sometime.
Sharkadder is offline   Reply With Quote
Old 28-04-2008   #6
XXX
My System: DM500+, DM800, CubeRevo HD, Sky UK HD x2, Viasat.
When i scan the sky active tps, i see no Date channels in Dreambox Edit
jayko is offline   Reply With Quote
Old 28-04-2008   #7
got this working and here is what you do.
1. Load dreamboxedit up, if you do not have a copy then download a copy
2. Get files from dreambox
3. Find the data channels services named 1380-1389 and also 1481-1489 if you wish for other interactive services on astra2 28.2east
4. Convert these from data to tv services using dreamboxedit
5. Send these files to dreambox
6. Reload settings on dreambox
7. If you already have banquets download the file called 'userbounqets.tv.epl' from '/var/tuxbox/config/enigma' and place it onto your desktop
8. Add in this line into that file at the top(underneath the NAME line i.e. second line in file)
#SERVICE: 4097:7:0be0a:0:0:0:0:0:0:/var/tuxbox/config/enigma/userbouquet.dbe0a.tv
#TYPE 16385
9. Save and copy the files 'userbounquet.dbe0a.tv' and 'userbounqets.tv.epl' back onto your box in the '/var/tuxbox/config/enigma' folder (on dm500-s or equivilent on your model)
10. Restart your box and bounqet should then display, select the bounqet and enjoy!!!!
Old 28-04-2008   #8
mhku's Avatar
My System: DM7020S ~ DM500s ~ sg2100 ~ Gemini
If he were not a wizard, from head down to the root, you would have got to worry-your DB only boots
Probably best to replace the smiley with a
:D
or use the CODE tag:
#SERVICE: 4097:7:0:Dbe0a:0:0:0:0:0:0:/var/tuxbox/config/enigma/userbouquet.dbe0a.tv
#TYPE 16385
You don't stop playing because you get old, you get old because you stop playing. Regras
Before posting in the Dreambox section please ensure you've read The Guide
Information is for educational purposes only
mhku is offline   Reply With Quote
Old 01-05-2008   #9
T_G
T_G's Avatar
#TYPE 16385
Sharkey, what is the purpose of points 7- 9? what exactly does it do? If it is just to create bouquets, then surely dreamboxedit is much easier to use?
T_G
Old 01-05-2008   #10
yeah probably is but i'm a coder lol.
I use captains settings you see and for a new bounqet you need to add it to the bounqet file. I know dreambox edit can do it but i find it just as easy to modify the file manually.
Your choice i guess
Old 04-05-2008   #11
XXX
got it working fine on 500+
Old 15-08-2009   #12
My System: dreambox
does anyone know how i can get free sports movies and all the other sky based channels on my dreambox what i need and need to too help would be much appreciated thank you in advance and as im new i dont know if what i typed here is somthing i shouldnt have typed soo sorry if im in wrong
ty007 is offline   Reply With Quote
Old 15-08-2009   #13
Site administrator
Analoguesat's Avatar
Lol if it was possible we would all be doing it. You need access to a subscription card.
Analogue forever!
Analoguesat is online now   Reply With Quote
Old 15-08-2009   #14
T_G
T_G's Avatar
Whatever you do, do not ever post such a long sentence without points and commas. What happens is that nobody will bother to read and answer it...
T_G
Old 15-08-2009   #15
and apostrophes
Burnham Beech is offline   Reply With Quote
active, choice, match, sly, sports
