Scanning HD Channels | |
| Dreambox Helper.... Join Date: 16-11-2005 Location: North West UK
My System: 24" Apple iMAC 2.8ghz Extreme - 4gb RAM 500gb HDD - ASUS Wamp Server - 20Mbit Cable - Sony Bravia 2500V - DM 7025CC 160Gb OLED - DM 800 S HD PVR 100Gb. Sky HD Full. Triax 80cm Dish. Motek SG2100 Diseqc Motor. | Hi guys I'm a little confused about the differences between SD and HD satellite equipment. I've read elsewhere about how to receive the BBC HD channel from 28e on my DM7025. I've managed to do this, but I only get sound only as the DM7025 can't decode the HD picture. However, I can stream it to my IMAC and watch it great. My question is, why can't I scan any other HD channels ? Do I simply need a HD tuner, and if so , why can I recieve BBC HD with my SD equipment. Any suggestions ? | ||
| Super Moderator Join Date: 08-03-2005 Location: J6 M5
Blog Entries: 1 My System: DM7020S ~ DM500s ~ sg2100 ~ Gemini ![]() If he were not a wizard, from head down to the root, you would have got to worry-your DB only boots | Do they show up as data channels? | ||
| | #3 | |||
My System: Sky UK. FTA analogue & digital satellite from 5 fixed dishes (5E/7E/9E/13E/16E /19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | Or possibly radio channels?
__________________ | |||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | BBC HD is still using DVB-S, as are one or two others (Luxe HD, ITV HD), so streaming is possible with a receiver/PCI card equipped with an SD tuner. The majority of other HD channels are DVB-S2, needing an HD tuner. Llew | ||
| The Following User Says Thank You to Llew For This Useful Post: | B16MCC (19-05-2008) |
| | #5 | ||
My System: 24" Apple iMAC 2.8ghz Extreme - 4gb RAM 500gb HDD - ASUS Wamp Server - 20Mbit Cable - Sony Bravia 2500V - DM 7025CC 160Gb OLED - DM 800 S HD PVR 100Gb. Sky HD Full. Triax 80cm Dish. Motek SG2100 Diseqc Motor. | No guys they don't show up after scanning at all. As I expected. Llew thanks for clearing that up. | ||
| | #6 | |||
| Specialist Contributor Join Date: 01-01-2000 Location: pj::
My System: Dreambox 7000S + motorised 80cm dish, Amstrad DRX550 Digibox + fixed dish | Incidentally, DVB-S2 can also be used to transmit standard definition TV programmes; it is not only for HD. There's a good article explaining DVB-S2 on the EBU site: _http://www.ebu.ch/en/technical/trev/trev_300-morello.pdf.
__________________ pc:: | |||
| | #7 | ||
My System: 24" Apple iMAC 2.8ghz Extreme - 4gb RAM 500gb HDD - ASUS Wamp Server - 20Mbit Cable - Sony Bravia 2500V - DM 7025CC 160Gb OLED - DM 800 S HD PVR 100Gb. Sky HD Full. Triax 80cm Dish. Motek SG2100 Diseqc Motor. | I'd have thought that spec would play the HD ts without issue. I stream BBC HD to my imac and without making any changes in VLC it plays fine. Maybe its the upper hand OSX has over windows ? I dunno... I'm pretty sure it will be performance related problem in some shape or form. | ||
| | #8 | ||
| Frequent flyer Join Date: 13-05-2005 Location: Windy & Wet Atlantic Coast
My System: DB7000s, mod PS, Phoenix on /dev/tty2, 250GB HDD, Smart Twin Titanium 0.2dB, Stab HH120 USALS 45E-45W, Triax 120, SkyStar II | easysat: It is the X1650 card, upgrade to Nvidia 8800 or ATI HD and the playback will be smooth. I had the X1650, 80% CPU on HD, jerky playback while 8800 GTX 15% CPU, no problems on ITV HD or BBC HD. Last edited by skydreamer; 21-05-2008 at 09:36 AM | ||
| The Following User Says Thank You to skydreamer For This Useful Post: | easysat (22-05-2008) |
| | #9 | |||
My System: Dreambox 7000S + motorised 80cm dish, Amstrad DRX550 Digibox + fixed dish | After taking a look at the graphic card specs, I think I will go for one of the ATI HD3850 cards at around £90, as they have a built in decoder for H.264 and VC-1 and MPEG-2 acceleration and draw a lot less power than the Nvidia.
