problem decrypting sky 3 | |
| Member Join Date: 02-04-2008 Location: Nederland
My System: Dreambox 500+ Gemini 4.50 Moteck SG-2100A Motor | Running: Dreambox 500+ Gemini 4.3 Ccam 2.0.9 sky card Hey Guys, I can't seem to get sky 3 to decrypt, (just get a blank screen), all my other channels work ok like sky 1,2, bravo etc. I've reinstalled Gemini 4.3 and Ccam 2.09, I've also tried Sif-team 1.9.0 and Ccam 2.05,2.0.8 and get the same problem?. Have a look at the pic i attached seems the box is receiving the channel ok?. (oh yeah, sky 3 works ok via my skybox) Any ideas Bren. p.s. just seen Gemini version 4.40 on satandream, maybe i should give it a try?. Last edited by bren; 04-06-2008 at 09:18 PM Reason: info | ||
| Super Moderator Join Date: 08-03-2005 Location: J6 M5
Blog Entries: 1 My System: DM7020S ~ DM500s ~ sg2100 ~ Gemini ![]() If he were not a wizard, from head down to the root, you would have got to worry-your DB only boots | Your symbol rate and frequency are different to my Sky Three: Frequency: 12227 Symbol Rate: 27500 Not sure if that's the issue but have you tried deleting the channel and rescanning? | ||
My System: Dreambox 500+ Gemini 4.50 Moteck SG-2100A Motor | Tried that also mate,but no luck there. I flashed to gemini 4.40 and used Ccam2.09 today, but still no sky 3?. what about Newcamd? maybe it would decrypt sky 3? Any ideas Bren. | ||
Blog Entries: 1 My System: DM7020S ~ DM500s ~ sg2100 ~ Gemini ![]() If he were not a wizard, from head down to the root, you would have got to worry-your DB only boots | newcamd might work. Is th eproblem the emu or the channel though? Is there anything on Sky Three worth watching? | ||
| | #5 | ||
| Frequent flyer Join Date: 13-05-2005 Location: Windy & Wet Atlantic Coast
My System: DB7000s, mod PS, Phoenix on /dev/tty2, 250GB HDD, Smart Twin Titanium 0.2dB, Stab HH120 USALS 45E-45W, Triax 120, SkyStar II | NewCamd/betad works fine with Sky Three. Just checked it a minute ago. | ||
| | #6 | ||
My System: Dreambox 500+ Gemini 4.50 Moteck SG-2100A Motor | sky 3 works fine on the digibox!, so it should not be a card problim. could it be a problem with the Ccam 2.0.9 that is downloaded via the gemini server?. how do i go about installing newcamd?, cardserver file i've downloaded, but i need to enter the box id into a file, which one? and were is it?. | ||
| | #7 | ||
Blog Entries: 1 My System: DM7020S ~ DM500s ~ sg2100 ~ Gemini ![]() If he were not a wizard, from head down to the root, you would have got to worry-your DB only boots | You can download all versions of cccam from i-have-a-dreambox.com in the database section of the website (you'll probably need to register). Try searching on boxID in the Dreambox section of the forum and you'll find some old posts on it. | ||
