Creating images - advice
Dreambox information exchange on the best dreambox software images and help with all other operational problems with your Dreambox. The ultimate Dreambox satellite TV support forum.
Old 09-06-2008   #1
My System: Dreambox 8000 HD PVR, 80cm Dish, 1.2 Compatible Motor, Quad LNB, Porty TV, Yamaha RX-V765 Amplifier, Tannoy Mercury FC Centre Speaker, 2 x Tannoy F1 Custom Speakers, 2 x Tannoy FR Custom Speakers, EPOS ELS Sub Woofer
Hey, ok you lot probably won't know all that much about this, unless you have tried it yourself but it's worth a shot.
Basically for a project i'd like to be able to create my own image, i know theres a tutorial on it in the sticky but that's not creating own image, that's just about how to compress a file into image format, kinda a cheats way.
Does anybody know where i can get the open source for image creation which is currently available, and also what computer languages these are programmed in?
I'd like to be able to take template code or sample code and either write an image myself or modify some previous code for what i need. the image will be for a dreambox 500-s satellite receiver.
p.s. is they any simulators floating about for loading images on? Would seem rather stupid having to flash my box everytime i want to test a new feature out. I know i will need something like fedora or ubuntu on my pc aswell as windows for this.
As i say it is going to be for a programming project which i will begin properly in october but i want to know if it is possible to do since i can start looking into it now.
thanks, any step in right direction is appreciated, anybody who has created or been part of creating an image before, then a pm woulsd be great on what i need to do :-).
Sharkadder is offline   Reply With Quote
Old 09-06-2008   #2
Dreambox Gimp & Coder
B16MCC's Avatar
My System: 2 Dreamboxes ------ DM 8000 HD PVR ------- ---------- DM 800 HD ---------- -------- Motek SG2100 -------- ---- Triax 80cm Dual LNB ----- -- Fixed Dish 28e Quad LNB -- ---------- Sky HD Full ---------- ------- 24" Apple iMAC --------
Creator of the CCCCC - only a true wizard could come up with such a name!!
As great as this forum is, it's more of a user's forum rather than a place where dev's hang out. I think you'd get better info elsewhere, for example, _www.i-have-a-dreambox.com
B16MCC is offline   Reply With Quote
Old 10-06-2008   #3
ok thanks, even though i barely understand half the German terms i shall give it a go.
See what i can find on there
Old 13-06-2008   #4
PCD
DB Magician
PCD's Avatar
Merlin of the Idiot Guide
It is a long road ahead - but you may start with the first post here :-
h**p://www.sat-industry.net/forums/dreambox-development/17990-howto-build-complete-image-any-dreambox.html
Regards, pcd.
PCD is offline   Reply With Quote
Old 17-06-2008   #5
Yeah, some developer got in touch with me, he's sorted me out on where to go for this sort of thing. It does look complex but i am usually a quick learner on thing's like this.
I hear a lot of the enigma 1 code is very sloppy indeed and at times very hard to make out what exactly you do need to edit. Another thing is theres currently no emulator available to test images on. So the only way is to flash the box everytime you want to test something. Enigma 2 code however is a lot more cleaned up, easier to understand, but i won't have a spare enigma 2 machine unfortunately to test it all out on.
advice, creating, images
