Help in connecting a USB card reader
Dreambox information exchange on the best dreambox software images and help with all other operational problems with your Dreambox. The ultimate Dreambox satellite TV support forum.
Old 09-06-2008   #1
International Administrator
rato's Avatar
My System: DM800; Nokia 9800s; Nokia 9902S w/T-Rex 3.66 w/ Inverto IDLP-40TL + Technisat 33 dish; Pace DS430N + Humax HDCI-2000 w/ Gibertini OP 1.25m dish w/Inverto 0.3dB. & Invacom 0.2dB. w/ Spaun SAR 411; CAS 3;FUN7; SkyStar2; AltDVB;
Question Help in connecting a USB card reader
I've been trying these last few days to connect my Infinity USB card reader to my DM800 but no luck. It lights up the blue light which means: "ready, but no card". I execute the dmesg in Telnet and it appears to have located it. These are the last lines after the dmesg command:
"usb 2-1: new full speed USB device using brcm-ohci-0 and address 3
brcm-ohci-0 brcm-ohci-0.0: GetStatus roothub.portstatus [0] = 0x00100103 PRSC PP
S PES CCS
usb 2-1: default language 0x0409
usb 2-1: wrong descriptor type 32 for string 3 ("?")
usb 2-1: new device strings: Mfr=1, Product=2, SerialNumber=3
usb 2-1: Product: Infinity USB Unlimited
usb 2-1: Manufacturer: WB Electronics
usb 2-1: SerialNumber: ?
usb 2-1: hotplug
usb 2-1: adding 2-1:1.0 (config #1, interface 0)
usb 2-1:1.0: hotplug
hub 2-0:1.0: state 5 ports 2 chg 0000 evt 0002"
I've tried in the CCcam.cfg file by adding the command "SERIAL READER : /dev/usb/tts/0 smartreader+" but still nothing. The CCcam entitlements info panel says: "no or unknown card inserted"(but with a card in the reader).
Any help or ideas are welcomed.
rato is offline   Reply With Quote
Old 01-12-2008   #2
My System: 13E Linux Ubuntu CCcam-2.0.10
same problem
plese replay if you solve the problem, i'm trying whole week but nothing.
I have Linux UBUNTU , CCcam-2.0.10, Infinity USB UNLIMITED.
dbacc is offline   Reply With Quote
Old 14-01-2009   #3
papampi's Avatar
My System: DM-600 -Ubuntu Desktop server GEMINI 4.60 CCcam 2.1 24x7 online with ups
I have the same problem with the same hard/software !
I have ubuntu 8
Infinity unlimited usb
CCcam 2.0.11
irdet showtime card !
gone through all steps nftytool
and :
"couldn't find the infinity device " comes up !!!
any one !!!!
should i get other card readers or ????
papampi is offline   Reply With Quote
Old 14-01-2009   #4
Dreambox Gimp & Coder
B16MCC's Avatar
My System: 2 Dreamboxes ------ DM 8000 HD PVR ------- ---------- DM 800 HD ---------- -------- Motek SG2100 -------- ---- Triax 80cm Dual LNB ----- -- Fixed Dish 28e Quad LNB -- ---------- Sky HD Full ---------- ------- 24" Apple iMAC --------
Creator of the CCCCC - only a true wizard could come up with such a name!!
Rato, I seem to remeber this topic some time ago. I'm sure you need to use infinity card reader with a USB to serial converter. So you don't connect the USB on the infinity at all. The simple converter lead costs about £10 . Also I think you need to set up the infinty in windows so it defaults to phoenix mode when connected via USB to Serial. Once you've done this your CCCam.cfg line should do the trick. Also, be sure you've got USB drivers enabled in your image.
B16MCC is online now   Reply With Quote
The Following User Says Thank You to B16MCC For This Useful Post:
rato (16-01-2009)
Old 16-01-2009   #5
Thanx for replay B16MCC, i'll try with USB to serial converter to see what's gonna happen.
card, connecting, reader, usb
