Internet Connection with Analogue Modem
Thread Tools Display Modes
Old 15-06-2008   #1
My System: Satellite Dish 1.6m Hotbird 13E, DreamBox 7000S with Gemini 4.4.0; Dish 1.2m Amos 4W, Nokia 9600S; Nokia 9800S; Hauppauge Nexus-S PCI Card
He battled for 3 days against the Tux and won! Hurray!!
Sometimes I have a weird problem with my ADSL connection at home. There is simply no connection to the internet which can last few hours and then all of a sudden there is a connection
So I am forced to use my good old analogue modem to connect so that I can check e-mails and the forum.
Just wondering if there is a way to connect any Dreambox (particularly 7000S) to the internet using the analogue modem.
Perhaps using the RS-232 connector ?
Thanks.
BTW: I am browsing now using analogue connection. It is not that bad really.
HB13DISH is offline   Reply With Quote
Old 17-06-2008   #2
My System: Dreambox 500-s, 80cm Dish, 1.2 Compatible Motor
i cannot answer the analogue question but it sounds like your line is corrupted. this happened to me a few year back. Sometimes internet was on for a few hours, sometimes for 5minutes and sometimes for a few days. I eliminated the wireless issue because i tried connecting via Ethernet and to my laptop and got the same effect.
you will have to get somebody round to do a line test, if you know anybody with a telephone line cable tester then you should get it checked out. If not ring your isp and ask for an engineer, they will sort it.
But it might just be the connection box that needs replacing due to oldness that leads to the outside world. We had to get ours changed as all the wiring inside was fraid and on it's last legs basically.
__________________
Sharkadder is offline   Reply With Quote
Old 17-06-2008   #3
Thanks Sharkadder for the reply.
This happens at certain times, usually in the evenings when there is a large number of people using the internet during peak times, so I will look into improving "something" in my subscription in order to stop it. This could mean paying more money for the line.
What I am really after is to use the box with analogue modem. My guess is Not Possible.
Old 17-06-2008   #4
Turok's Avatar
My System: 1,25 Fibostop Jäger Smr 1224 Dual Axsis Echostar Dvr 7000 Monterey 140 Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesch for cband!
in past i always using us repotnics modems sporkster !
how fast is dsl in israel?
prices are now in austria lower 3 years ago was very expensice 50€ for 2 mbit,now i have since 2 weeks 8 mbit for only 30€/month!
on dsl +2 ,
when you are to far away from the dsl dlan,and the quality is not good of the line the modems stops synchroneizing on old dsl +1 thomson modems i always have the same problem,then nothing works i change to slow isdn line many many years coz always interrptions on dsl,now dsl +2 is much better,first i try cisco modems,normaly they are very good,but when your line is bad,then they not syncrhoneize and lost singal,now,the post technican,install a new alcatel/thomson speedtouch,router,and it works much better,then the cisco ,with 12,5 db Signal lost,the test programm told,no interruptions since the change of my modem!
Turok is offline   Reply With Quote
Old 18-06-2008   #5
My System: Skymaster DCI9900 + PC/twinhan combination. 80cm dish. GBPVR with 2 DTTV cards +hauppauge Media MVP
Is your phone line quality OK? A couple of years ago I has a similar problem and used to hear a lot of crackling when making a phone call. Turned out to be a damaged cable where it entered the house.
pgh13 is offline   Reply With Quote
Old 18-06-2008   #6
Phone line is OK.
The ADSL line is not the issue here. Will sort it out somehow.
Forum Jump
All views and information expressed in users' communications and profiles represent the opinions of the users concerned and do not represent the views of Satellites.co.uk. All images and news content are believed to be in the public domain, except where otherwise stated. Forum software by vBulletin® Version 3.7.2
